RJS
Hey,
Gotta a TR4A with at motor rebuilt 10 years and 7K miles ago. Started suffering crankcase pressurization and oil leaks this past year. The leaks are pretty bad, most seals and a 3-6" puddle under the rear main seal after a 45 minute cruise. Here are the vitals:
Dry compression: 180/180/180/180 psi
Wet compression: 208/200/200/200 psi
Spark Plugs: look perfect, light tan powdery look
Intake Vacuum: a nice 20" Hg at idle
PCV: completely serviced, even replaced with new from Moss
Oil: Castrol GTX 10W-40
Other than the oil leaks, the motor starts, idles and cruises perfectly. Returns ~22mpg. If I remove the PCV and run a breather on the crankcase, it barely leaks a drop. (I know, I know, I know...I could leave it there but, I am dying to figure this out).
Any ideas what's going on? I have narrowed it down to a few theories.
1. given the compression numbers above, is the blow-by excessive? If so, would moving up to 20W-50 oil fix this?
2. alternatively, does it appear this motor is running a higher than stock compression ratio which is OK but creates extra blow-by volume which the stock PCV cannot process?
3. If all the engine gaskets are shot, could it be pulling in too much outside air, overwhelming the PCV which then shuts down (to avoid a massive intake vacuum leak) thus, pressurizing the crankcase?
Whew! To many variables and dynamics at work here!
Would appreciate any and all thoughts on this one.
Cheers
Bob
Cheers
Bob
