Oil between MIN and MAX
dondel
Hi all,
well I am new to this forum, as well as in owning an Healey.
This brings me to many questions (perhaps stupid ones, but hey... we all have to start somewhere), I hope to find an answer to here.
I had a question concerning the amount of oil to add between the MIN and MAX in the BJ8 engine. I always have to guess how much to add, start engine in order to "mix" the old and new oil and recheck if the level is high enough (but not too close to the MAX).
Does anybody know how many liters or pints (US pints!?) are between the MIN and MAX?
Thanks in advance!!
Andy65
Welcome to the forum. I cant' give you the exact answer but if it is at min, add 1 qt and it will be good. It will be just short of the max mark.
glemon
As long as it is over min don't worry about it too much, these motors have relatively huge oil capacities compared to the 4 quarts held by most modern cars, plenty of reserve to lubricate and cool the motor.
dondel
dondel
Thanks for your advice! Just for my understanding, a quart is 1/4 US-gallon, right? So basically 0,9 Liters.
AUSMHLY
The BJ8 takes 7 US quarts.
4 US quarts to 1 US gallon.
2 US pints = 1 US quart
1 metric liter = 1 US quart
Better not to over fill or you will need cat litter. Sort of self adjusting. My BJ8 is best at half way between and the rest in the boot for refills.
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
K STP oil additive between changes? Triumph 17
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
