new dist cap doesnt work... please help!!!!
gokuboy26
Hi folks!
I have a 66 midget. It has the 25D distributor. The cap has the wires that come out the side... I wanted to upgrade it so the wires can come out the top.
I was told the cap with lucas part number DDB106 would work with it. I got the cap, it fits perfect... I swapped out the cap and wires, but now I get no spark at all.
The rotor is new, but I had replaced it a few months back.
I'm not sure if it makes a difference, but it does have the pertronix ignition...
Any ideas? Am I wrong to assume the stock side-wires cap can be converted to a top wire?
JPSmit
Not sure about the part interchange - repost on the Spridget board (Sprite + Midget) and you will likely get a better answer. That being said, are your wires still in the same order, or, is the cap 180 deg. out?
tdskip
Wire location shouldn't make a difference, but as said don't assume that the cap is correct even if it seems to fit.
Did you change anything else? Wires all making good connection with the cap?
Do you have power to / from the coil still?
G
gokuboy26
Thanks for the tip... I reposted on the spridget board... maybe they have tinkered with changing out caps...
I don't have a garage...(regrettably)... so I have to try to work on the car while its light out.. and I keep getting home just before dark! lol...
I didn't change anything else out. The day prior to my changing the cap and wires It idled fine! and those were the only things changed.
I checked just to make sure I didnt pop a wire off the coil... but its all still hooked up..
I suppose I could have put some wires back on weird... it was difficult to follow the wires on the old cap that has them go in sideways... but even if a couple wires are swapped shouldn't I at least get a backfire or misfire here and there?
The cap only fits one way, so it can't be 180 off... good thinking though.
I'll mess more with it more tomorrow. hopefully I figure it out quick! My 10 yr old has been wanting me to teach him how to change the oil, and we want to run some engine flush through it, so it needs to run for that!
mgbsteve137
First, make sure the distributor cap is actually for a 1966 Midget with a 1098 cc engine and not a 1975 and later 1500.
I don't have a Moss catalog to hand at the moment. My VictoriaBritish catalog doesn't show a top-entry cap for the 948/1098/1275 cc engines from 1958-74, just the o side-entry cap. It does show a top-entry cap for the 1500, and I suspect each electronic ignition system has a cap specific to it's manufacturer.
My '72 'B still has the 25D distributor and it takes a top-entry cap. Both styles are available for the 'B but possibly for different years. I don't know if the Midget and the 'B are interchangeable. I seem to recall seeing different wire sets listed for each style of cap.
PAUL161
Steven, Here's the Moss web site. Put the link in your computer. Even if you never ordered anything from them, there's a ton of information and illustrations to look at. Use the menu at the left for car type and go from there. Hopes this helps somewhat. PJ
https://www.mossmotors.com/
MG, Triumph, Austin-Healey, Jaguar, Classic British Car Restoration Parts & Accessories - Moss Motors, Ltd.
MikeP
There should be a little spring loaded carbon brush from the center of the cap to the rotor to transfer the energy from the heavy coil lead to the distributor. If it's not there that would mean no spark.
emmett1010
The MG/Triumph dizzys have two sizes of caps and two sizes of rotors.
The caps are different in the distance from the center electrode to the wire electrodes. Both size caps will fit the distributor, but you must use the correct rotor.
You probably just need the longer rotor.
Emmett
PeterC
Emmett
HUH? 4 cylinder vs 6 cylinder is the difference The early TR4 cap will fit a Spridget, both are sidewire with pierce screws, but are 180 degrees out.
A 25D4 rotor is a 25D4 rotor.. except Fords which rotate backwards.... ie CW.
I think he just messed with firing order.
emmett1010
He says that he has no spark-- That has nothing to do with the firing order.
I have fought this rotor/cap battle, and I don't think that the rotor/cap combination is correct. If the rotor is correct, then the cap is wrong.
Emmett
mgbsteve137
Thanks, Paul, but I use the Moss, V-B, and LBCC web sites all the time, and I have paper catalogs for both Moss and V-B, both MGB and Spridget. I was away from my computer and most paper catalogs. I only had my Android phone and an old V-B Spridget catalog when I posted that message. <GRIN>
Mowgli81 Starting Problem Ignition coil? Dist. Cap? Austin Healey 21
NutmegCT Dist cap Triumph 19
JohnnyO Dist cap and plug wires Spridgets 6
G need help with dist cap conversion!!! Spridgets 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
2 TR2/3/3A comment on dist. wire [Ebay] Triumph 4
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
rjc157 Pertronix dist Austin Healey 2
B Petronix Flamethrower Dist. Austin Healey 20
K TR2/3/3A TR3 Dist Pedastal Tachometer Attachment? Triumph 3
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
hondo402000 how to Check total Advance on Dist Triumph 9
A Mallory Dual Point Dist MG 6
R 1500 midget & 25d4 dist change suggestions Spridgets 6
A dual vac dist Triumph 6
64rocksprite Int trim and dist parts I cannot find-ideas? Spridgets 8
NutmegCT TR2/3/3A timing DM2P4 dist, TR3A - vacuum? Triumph 37
B Pertronix and Dist Rebuild - Car not starting Austin Healey 63
DNK Dist. Roll Pin Triumph 8
tahoe healey Dist. A/R adjustment Austin Healey 9
D wire from coil to dist Spridgets 1
B Wedge TR8 Dist Triumph 0
DNK Elec. Dist. Triumph 9
G TR6 TR6 Mallory Dist Triumph 10
L Gas Cap Recommendation Austin Healey 1
mctriumph TR2/3/3A Hub cap emblems Triumph 2
L T-Series Gear box servicing cap. MG 5
C MGB New plug wires and distributor cap MG 10
F Wanted Dipping switch cap Triumph Classifieds 1
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
Overdrive45 Trim Under Convertible Cap Austin Healey 11
E TR6 Strange Steering Rack Cap Triumph 3
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
P MGB Mgb gas tank cap MG 7
A TR6 TR6 Distributor cap issue Triumph 4
charlie74 TR6 Bearing cap bolts Triumph 8
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
M TR6 Center cap for wheels Triumph 2
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
S TR2/3/3A TR3 gas filler cap Triumph 1
Ripper01 For Sale TR-6 Valve Cover/ Cap Triumph Classifieds 0
K TR2/3/3A Plugged valve cover breather Cap? Triumph 4
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
Jayplum TR2/3/3A Grease cap Triumph 25
