TR6 need carb parts
Sumton
i have a triple carb ZS setup, and i decided it was finally time to get the triple choke cable. only problem is I am missing a couple of critical components.
see: https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=32750
part #41, and then the part just to the right and below is nla. plus i need the little hex headed screw that holds the cable itself in lower on the body of the carb.
anyone willing to sell me these parts? please don't tell me to contact Joe Cuerto of the like; i'll go that route if i need to.
www.ranteer.com/davescars/tr6
What you got against Joe ?
You don't owe him money do you ?
Goodparts also has that setup, so they may have what you need.
Perry
I don't know exactly what the difference is between the brackets or how interchangable they might be, but which bracket is needed may come down to which carb number the OP needs the bracket for. Up to and including 1972, the same bracket was used on the front and rear carbs. In 1973 only, a different bracket is called out for both the front and rear carbs. For 1974 and up, the '1973" bracket is used on the front carb while the rear carb used the "up thru 1972" bracket.
From looking at the OP's webpage, I have to assume that he has asked around within the Red River Triumph Club. Dave, have you tried talking with either Byron Carlson at Sportscar Warehouse in Arlington or Jeff Sloan at British Auto Specialists in Haltom City/Fort Worth(?)
If it's any help, the Zenith part numbers are ZEB17088 for the "up thru 1972" bracket and ZEB22931 for the "1973" bracket. Triumph part numbers are 517001 and RTC1276 respectively for those brackets.
LastDeadLast Help! In need of HS carb parts Jaguar 9
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
H T-Series Need carb linkage info for my TD MG 1
E Need SU Carb help Austin Healey 5
G MGA Anyone need MGA carb kits? MG 0
vping I need some carb help. MG 8
G Anyone need a bigger 4bbl carb? Triumph 10
58Custom How often should carb damper oil need topping up? Spridgets 4
Bruce_B HIF44 Carb Questons - need some information Spridgets 16
N TR6 need the carb mounting stud size for 1974 TR6 Triumph 14
AUSMHLY I may need a carb chamber & piston Austin Healey 14
Baz Need a carb part..... Spridgets 4
TR_JOE250 Spitfire Spitfire carb need help/opinions Triumph 6
F Wedge 1980 TR7 ZS Carb rebuild advice [need some] Triumph 5
A Spitfire Bad carb on 78 Spit-need suggestions Triumph 2
martyc T-Series Carb Rebuild on the TD...boy did they need it! MG 7
A Hi I'm New here , Need Advice on SU Carb Filters Triumph 0
A Hi I'm New here , Need Advice on SU Carb Filters Triumph 5
J SU HS6 carb need help Triumph 10
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 2
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
