Napa Gold oil filter
Newkie
I am changing the oil in my 73B roadster and the filter that was on it was the Bosch 3330.
My question is:
I bought a Napa Gold 1348 that is the cross reference to the Bosch 3330. These filters are tiny, I mean really tiny, but it is the same dia. as the adapter base. Is this a normal size or did the PO just happen to use this size filter adapter when he changed?
Thanks
Newkie
P.S. I also bought 4 qts of the NAPA 20W50 performance oil. After further reading in other sites, is it true that the 1800 takes just over 4 qts?
RickB
Understanding that I have the Datsun 1500 installed before I say the...
When I went to get a replacement the guy at NAPA said - hey, these are the ones we sell for riding lawnmowers! I said: Hey, that's why they look familiar to me, I have two of them on my mower right now!
Newkie
Newkie
Does that mean, you do have one of those ultra small filters?
I noticed they are used for Motorcycles and tractors too.
Newkie
Scott_Hower
NAPA Gold filters are made by Wix (Dana). The part you want is 51068. This is the large filter can with an anti-drain back valve. A 73 has the top mount filter head; without the drainback valve, the filter, well... drains back into the sump leading to a dry-ish start. .
IMO, the Wix filter is about the best on the market; perhaps behind the K+N which costs about 3x as much. I no longer use FRAM filters.
EDIT: looking at the WIX website, the specs on the two part numbers are nearly identical, so the filter you are using should be fine.
Mac_Townsend
Be careful about too small.
There is a standpipe in there that can jamb up against the top of the filter and cause you no end of grief.
I get my Wix filters from Rockauto.com for a bit less than $4 each, I usually buy a dozen or so at a time (for all our cars...about 6 at last count).
T TR2/3/3A bad napa points Triumph 9
T TR2/3/3A Napa dot5 ok Triumph 4
C NAPA master cylinder rebuild kits Spridgets 19
tahoe healey oil sale at NAPA Austin Healey 4
glemon NAPA or other Parts Numbers for Triumph Parts Triumph 9
apbos TVR in NAPA Ca TVR 3
C Castrol on sale at NAPA Austin Healey 2
A NAPA Radiator Hose Equivelent Austin Healey 11
AUSMHLY Oil filter, K&N vs. Napa Austin Healey 2
G TR5/TR250 NAPA U joints fro TR250/6 Triumph 5
Gray_Cat Bugeye For Sale in San Diego [and Napa] County Spridgets 4
J TR4/4A TR3, TR4 bypass hose needed , NAPA #? Triumph 2
tahoe healey Gold Sparkle in Oil Austin Healey 15
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
HealeyRick Gold Level Concours Value Austin Healey 20
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
B Gold TR8 Waxhaw N.C. Spotted 2
2 TR2/3/3A Classic Gold TR2-4 water pump Triumph 5
S TR6 Gold stars for TR3Driver&NutmegCT: it's a fuel delivery issue Triumph 9
steveg Moss Classic Gold 7 lbs. cap now "sucks"! Austin Healey 0
P Guages with gold rings Spridgets 2
B TR6 How restore the "gold" finish of TR6 door latch? Triumph 4
K Gold in the junk yard Triumph 5
Michael Oritt VIR Gold Cups/ACME SPEED SHOP Racing 1
PeterK TR2/3/3A Classic Gold TR3 Master Cylinder Triumph 2
HAN8L1965 Found Gold Spridgets 14
angelfj1 Warning - Moss Classic Gold Master Cylinders MG 0
angelfj1 Warning - Moss Classic Gold Master Cylinders TVR 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Spridgets 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Austin Healey 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Lotus 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Jaguar 0
AngliaGT "Classic Gold" Water Pumps MG 2
T Free Dunlop Gold Seal 5.20 13 bias ply tyre Spridgets 5
M VIR GOLD CUP THIS WEEKEND TVR 0
S Gold Wheels MG 8
Sherlock Emoticons & the new Black/Gold style FORUM Navigation Questions 2
jerrybny Classic Gold Semi-Metallic Brake Pad Set Triumph 2
Jim_Newman gold cylinder head Jaguar 4
healyfan53 Barret J. vs Gold concours BT7 1960 on the block Austin Healey 23
JeffR Thanks for all the help - Gold! Austin Healey 4
S VIR Gold Cup Historic Auto Race Photos Racing 1
G T-Series What is a MG TD "Gold Seal" Engine? MG 17
Bret Gold Corvette Other Cars 20
Webb Sledge Gold Cup Race Pictures... Again MG 3
Webb Sledge Gold Cup Race Pictures... Again Triumph 0
dklawson Pictures - VIR Gold Cup MG 3
dklawson Pictures - VIR Gold Cup Austin Healey 10
dklawson Reminder - Gold Cup Races at VIR Start 6/10/05 Austin Healey 2
Webb Sledge Gold Cup Historic Races Triumph 1
