My speedometer isn't working... :[
77_MG_Midget
I figured I'd separate my 2 questions.. make it easier... So during my first short test drive, I noticed the speedometer isn't working. It did work before the car was taken apart.
I've narrowed it down to the cable going into the trans. The cable looks good on the ends, so I took it back out of trans and reinstalled it to make sure it was in correctly. Still nothing. Any thoughts on what to check next?
JerryB
2 for one.......
Disconnect speedo cable at speedo. Jack one rear corner up and rotate rear wheel so as to turn driveshaft.....clutch in and in hi-gear. See if cable rotates. If so its in the speedo . If not work downwards > cable > speedo driven gear in bullet/trans hole > drive gear on output shaft.
Rack or front suspension.....nut and bolt the rack mounts, steering arms and a general suspension look see. Check rack play which should be very minimal. check splines on pinion input and steer shaft. Check for proper pinch bolt. Somethings moving.
M TR2/3/3A HVDA Speedometer Drive Triumph 10
GeorgetheTR3 TR2/3/3A Speedometer Triumph 4
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
roscoe GPS Speedometer Austin Healey 6
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
DocDup1 MGB SpeedBox Speedometer Drive MG 0
R TR2/3/3A Speedometer Reset Triumph 26
BritBite Speedometer Right Angle Drive Austin Healey 5
roscoe GPS Speedometer Austin Healey 10
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY Speedometer Fluctuation Austin Healey 21
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
M TR6 Speedometer Triumph 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
P TR6 Jumpy Speedometer cable Triumph 4
PAUL161 T-Series Interesting Speedometer Scenario MG 5
John Turney Getting Speedometer out of the Case Austin Healey 6
K TR2/3/3A Speedometer needle bounce? Triumph 1
P Speedometer confusion Spridgets 1
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
RJS TR4/4A Speedometer and Angle Drive Triumph 6
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A Speedometer Works Removal Triumph 10
R TR2/3/3A Speedometer Routing Triumph 15
KVH General Tech Speedometer Not Working Triumph 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
K TR2/3/3A Speedometer Error Again Triumph 8
G Spitfire gps speedometer Triumph 6
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S Speedometer Angle Drive Austin Healey 2
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
F How does overdrive Annulus effect speedometer Austin Healey 10
M TR4/4A Speedometer Cable Routing Triumph 7
2 TR2/3/3A Can't get zero on speedometer 60K tr3A Triumph 6
B Speedometer Cable Routing Austin Healey 9
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
Michael Oritt Speedometer drive issue Austin Healey 4
R TR4/4A Speedometer off 10mph Triumph 6
R BN7 Speedometer issues Austin Healey 1
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
N Wanted Speedometer or dial Km/h for BT7 Mk II - buy or trade for MPH Austin Healey Classifieds 0
K Speedometer Drive Gear Issue w/ Smitty/Delaney Tx Conversion Austin Healey 16
