MOWOG oil pump cover- attachment to back plate?
chrpark
on the 948cc motors, what holds the round MOWOG oil pump cover to the backplate? Does it go under the bakplate, between the backplate and the block? Or some sort of gasket adhesive just attached to the backplate itself?
THANKS
Billm
It goes between the block and the backplate, usually soldered to the backplate but not always.
The block to backplate gasket seals it up.
BillM
jlaird
Excuse please. On a 948 the cover goes on the outside back of the backplate and is held on with solder or in my case brazeing. Solder from the factory.
chrpark
chrpark
Aha! Didnt think it would fit behind backplate without creating a gap. Now have to figure out the solder or brazeing
thx
jlaird
Brazing is easy, take it to your friendly welding shop. I have seen sodder crack/melt from time to time and destroy an engine. Folks were not watching temp and oil pressure I guess.
Brazing is for ever.
Billm
I will agree with Jack since it has been a lot of years since I played with a 948 (I thought that they were the same as the 1275) and any radiator shop should be able to solder the can on.
Bill
jlaird
Good point on radiator shop, did not think of that.
JPSmit Need a MOWOG and very confused Spridgets 13
Superwrench MOWOG parts Austin Healey 3
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
