Manifold stud threads.
burgundyben
On my MGA the nuts holding the manifolds onto the head are brass, a 1/4 whitworth spanner seems the best fit.
On the 1800 B engine that is going in the brass nuts dont feel quite right.
what thread on a MGB 18V manifold stud?
Thanks again!
BB
Probably good old SAE sizes for the MGB engine.
Platinum
Absolutely SAE. 5/16 NFT, IIRC.
Platinum
National Fine thread... UNF is likely a more correct term. Sorry for the confusion.
The studs may have coarse on one (head) end, fine on the other, too. Can't recall and ain't gonna pull one out just now. :wink:
But they're 5/16" fine at the exposed ends.
1965_MGB
The ones on my 65 head are fine on both sides. Replacements are usually coarse on one side, fine on the other.
5/16-24, as mentioned on both sides, you'll not find these studs to be run of the mill, meaning you can't noramlly find them at your local fastner stores, luckily you find them readily available at your normal MG parts vendors.
19_again
I just had to deal with this as my furthermost rear outer stud was loose (due to a cross thread) and making a racket, I had to remove it but I had a spare from Moss, I always order spares (tony said it was better that way). Anyhoo my MOSS #328-900 has different threads, 5/16 18 on the inner end and 5/16 24 on the exposed. What is the conflict here, before I go and tap my cylinder head to accept the new stud. Do I receive the wrong stud?
Mike
Platinum
The best thing to do would be HeliCoil the stripped head with a 5/16-24 insert and find the correct stud, Mike.
B
burgundyben
Indeed helicoils are excellent.
I got to the bottom of the mystery on my car, the studs are 5/16 UNF both ends, the old brass nuts are 5/16 UNF, but they are not 1/2 AF spanner size, they are a bit bigger! 1/4 whitworth spanner was a good fit.
New brass nuts are 5/16 UNF and a 1/2 in spanner fits.
Smart!
Platinum
Elitist! :jester:
Platinum
They're a full insert, a sort of self-locking thread replacement "sleeve", where HeliCoils are a hardened wire system, open wound into a larger tapped hole. The HeliCoils can be a bit of bother setting them compared to the Timeserts. If you need flush threaded holes the Timeserts have to have the hole they're wound into relief cut for their shoulder.
19_again
On the same thread I just discovered that one of the inner studs is stretched to the point where it's almost hourglass shaped, really amazing. How do you get these bad boys out when they're not crossthreaded and loose? pb and drill a hole through the diameter for a lever of some type?
spin 2 nuts down over the exposed threads, tighten them against each other as hard as you can, then turn the bottom nut to spin the whole stud.
Platinum
The "double nut" method works most of the time, I prefer a "sprag" type stud removing tool. It applies the force/torque closer to the threads and across more of the stud surface than two nuts. An excuse for a new tool!
If you have "hourglass" shaped studs, Mike, that's amazing... and scrap. Who was th' gorilla wot torqued THAT down??!?!? :jester:
Yes, stud sockets do make life a bit easier, plus as mentioned, a reason for some new tools :smile:
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
S TR4/4A Exhaust manifold missing stud Triumph 8
B TR4/4A TR4A Head off for broken manifold stud - What else to do ? Triumph 13
J TR2/3/3A TR3 exhaust manifold stud thread size? Triumph 3
HealeyDave Exhaust Manifold Stud Removal Austin Healey 18
Spriteman65 Manifold Stud size Spridgets 5
davester Help needed...broken exhaust manifold stud MG 15
Jim_Gruber Replacing Exhaust Manifold Stud Spridgets 4
John Loftus Exhaust manifold stud .. equiv. source? Austin Healey 10
6 Stripped exhaust manifold stud Austin Healey 5
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 2
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 7
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Carlbanan56 MGB Manifold plug MG 5
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
V MGB Replace late intake manifold angled breather with early model straight? MG 1
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
M WANTED......Cannon Inlet Manifold Triumph Classifieds 0
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
steveg TR6 Fixing the intake manifold Triumph 8
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B AH Spares Ltd. Inlet Manifold No. FUL 340 Austin Healey 2
Michael Oritt Intake manifold question Austin Healey 11
Michael Oritt Manifold Gasket Dressing/Sealant Recommendations Austin Healey 6
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
D TR2/3/3A manifold studs..locktite or antiseize Triumph 5
steve00136 MGB Intake manifold alignment MG 4
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
