TR6 Looking for TR6 caliper "brackets" for TR3A conver
Dyrk
I am in the process of installing TR6 brake calipers on a 1959 Triumph TR3A and I am in need of TR4 or TR6 brackets to mount these calipers.
Can anyone help?
DNK
Re: Looking for TR6 caliper "brackets" for TR3A conver
If your going that far.
Why not use the Toyota brakes Calipers?
DNK
That's what I was wondering.
Specially since ,Does the 3 have a booster?
Darrell_Walker
I believe the TR5/250 is the first TR with a booster.
TR4nut
Well, the later setup is certainly lighter - in my mind from a weight standpoint it would be an improvement.
DNK
Well, then that would be a plus.
Anybody know the weight difference between the Toyo caliper and the TR6 one?
TR3driver
Great Pumpkin - R.I.P
No, but I know the rotor is smaller diameter, which to my mind makes the brakes inferior. Larger rotor means more swept area, which means better cooling. The larger rotor should also reduce pedal pressure required (all other things being equal, which they aren't). TR3s never had a booster, because they didn't need one!
DNK
Which rotor is small Randall?
Geo Hahn
My TR3A has 11" rotors -- how does that compare to other choices?
TR4nut
I bet if you checked the vintage racers out there few run those big caliper setups but instead aim for lower unsprung weight with the TR6 style setup. The early rotors were 11", the later TR6 style 10.75". Again, I'm staying with the early ones on my 3A just because I have a good set, but if I didn't have a set I wouldn't hesitate to put on the later versions.
TR3driver
Could be, but my guess would be that if the rules allow that kind of modification, they would be running Wilwood alloy calipers and the biggest Brembo drilled rotor they could get inside the wheel. Overheated brakes are a persistent problem on the race track.
Seems to me it was "Mad Marx" (who posts video links on here from time to time), who was talking about commissioning some higher temperature dust seals, because he routines cooks the stock ones.
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
Got_All_4 TR6 Looking at clutches and their differences for my 69 TR6 Triumph 14
S TR6 new TR6 owner looking for advice Triumph 9
D TR6 Researching potential next project car - Looking into TR6 Triumph 5
Got_All_4 TR6 Looking for a reverse gear for my tr6 gearbox for my tr3 Triumph 7
rustrocket TR6 Looking for TR6 flared fenders... Triumph 9
J TR6 looking forgood shop to fix my tr6 Triumph 2
bgbassplyr TR6 Looking for a TR6? Triumph 2
TR6BobNF TR6 Looking for TR6 Radiator Shield Triumph 7
G TR6 Anyone looking for a TR6 Hardtop? Triumph 22
D TR6 Looking for some TR6 wiring connection info Triumph 15
Woodie TR6 looking for a TR6 Triumph 16
TRnorwegian TR6 I have Webers in my TR6 - now looking for SUs Triumph 24
Steve1970 TR6 Looking for pics of your green tr6 Triumph 21
C TR6 Looking for a TR6 Triumph 6
Z TR6 Looking for one .060 TR6 Piston Triumph 18
Brosky TR6 For those looking for a restored TR6, your answer Triumph 21
MadRiver TR6 Looking for a TR6 Triumph 13
Brosky TR6 Who was looking for the late TR6 exh manifold? Triumph 10
Brosky TR6 Sweet Looking TR6 in Oregon low miles Triumph 2
2wrench TR6 Looking for tips on folding soft top TR6 Triumph 11
F TR6 Looking for TR6 metal dash support Triumph 4
Brosky TR6 Looking for tire advice for TR6 Triumph 17
G TR6 Looking for a knackered head for a TR6 Triumph 14
R TR6 Spridget Guy looking to purchase a TR6 Triumph 17
T TR6 Looking for a TR6 Triumph 3
V TR6 Looking for TR6 repower options. Triumph 10
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
