TR4/4A Locating a specific TR-4...
sevendreams
Hello: I am new to this forum and this may be a ridiculous question but, I used to own a 1963 TR-4 and I would like to see if it still exists and if it might be for sale (it was my first car). Knowing the chassis number, is there any way to try and locate a specific vehicle? Thank you.
KVH
You're asking what I asked years ago. After some detective work, I was fairly certain I had found my hood, fixed and repainted on another car. As for the rest of my old TR, I was told that it likely was sold and sent for parts back in the 80s. Apparently, there was a tragic period when the cars were worth a lot more back in Europe, and several waves of LBC cars headed that direction.
I gave up looking for mine, despite a tremendous desire to let my old car know how sorry I was, and how I so much regretted the shag carpet, the 8 Track, the horrible chrome wheels, the bondo and some other atrocities.
Better luck to you, and I guess I'd check all the wrecking yards anywhere near.
As for me, I just have to live with what I did.
mrv8q
I've seen a guy at the past couple of Triumphests who has a big printout of TRs and their commision numbers, along with named owners of some of those cars. Sorry I don't know fhe name of that fellow; perhaps someone here know him?
Andrew Mace
I suspect that's Jon Korbin, vehicle registrar for The Vintage Triumph Register.
Geo Hahn
sevendreams said:
...Knowing the chassis number, is there any way to try and locate a specific vehicle?
Be aware there are several numbers on a TR4: Body number, commission number and engine number.
Cars were usually registered with the commission number which would have ended in 'L' or 'LO' (as in CT?????L). If the number you have is the commission number then your chances are improved as most registrys will list by that number.
I suppose you could mention the number here if you're felling lucky.
S
sevendreams
Thank you for all your help and suggestions; I will check the resources that have been suggested above. The car I am looking for is a 1963 TR-4 that I purchased in 1972 in Northern California (and sold there in 1975). Original color was a light blue, chassis #CT 13164 L, engine #CT 13300 E. Again, thank you all.
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
F TR2/3/3A Locating Original Motor Triumph 9
CJD TR2/3/3A Wire Wheel Locating Collar 108942 Triumph 15
B TR2/3/3A Locating source of oil leak Triumph 6
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
W MGC Basic Information for locating identification numbers on MGC's or MGC-GT's MG 1
K TR6 Flywheel installed without the locating dowels? Triumph 5
RGK Need help locating parts MG 0
T TR6 How many alloy locating dowels on TR6 trans Triumph 6
T Tips for locating/fixing foam rings under gas tank Triumph 4
mjobrien Cap Nut on Oil locating screw Austin Healey 2
Trevor Jessie Front brake line locating brackets [disc]. Spridgets 6
M Camshaft locating plate Austin Healey 11
Atrus Help locating pics [I hope!] Spridgets 3
D What is this thing? Rear end locating device? Racing 12
J Need help locating an accurate wiring diagram MG 5
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
JPSmit A fairly specific looking bolt Spridgets 10
nevets NYT article about the Pebble Beach Auction - not Healey specific but relevant... Austin Healey 5
A Posting in a marque-specific forum FORUM Navigation Questions 1
bighealeysource Looking for specific # cockpit surrounds for BN2 Austin Healey 5
J Specific battery for a negative ground? Triumph 4
tomshobby specific front wheel bearing questions Spridgets 8
hondo402000 TR6 flushing your cooling system, TR6 car specific Triumph 14
drooartz New specific plan for fuel pump install Spridgets 23
V New Midget-specific website Spridgets 1
jjbunn MGB MGB Registration Questions [CA specific?] MG 15
P Any TVR specific vendors out there? Other British Cars 6
C Looking for a Specific part Spridgets 2
M New here, Is there a MK1 MK2 specific board? Jaguar 2
T How to tell the specific model distributor install Spridgets 10
C Looking for a Specific Distributor MG 60
C Looking for a Specific Distributor Spridgets 16
