Ignition Keys - Vendor Recommendations Please
dklawson
I know that the usual vendors have ignition key blanks suitable for my '72 Spitfire. However, their prices for the "WS" type key blank I need run anywhere from $15 on up.
The PO of my car installed a new lock and I only have one key. I'd like to have a couple of extras but I'd like to get a better price than $15/each before I have them cut.
If you know of a good source for these key blanks, please share it with me either here or in a PM.
Thanks,
TR3driver
Great Pumpkin - R.I.P
You might check with George at https://www.key-men.com/ or poke around on eBay.
Also Pete Groh at https://www.britishcarkeys.com/
If you can link to someplace that shows the design, I might even have one in the parts bin. I bought a couple of assortments that came with a lot of keys I didn't need.
dklawson
dklawson
Thanks for the links Andy and Randall.
The blank I'm looking for is a type "WS". If this link works, you can see the profile in a picture from Moss' catalogue.
https://www.mossmotors.com/Graphics/Products/Large/BAC-431.gif
The picture is looking at the end of the key like it was pointing at your eye.
I searched the NASS Yahoo group threads on the subject and one person implied that a certain later model Mazda key blank could be used but they didn't say which Mazda the key was for nor did they identify which BL key blank (and there are a bunch of profiles) the Mazda key matched.
There is one older locksmith in my general area. The only problem is he does not have weekend hours and is too far for me to drive to during business hours. However, your suggestion of an older locksmith might still work. I just need to focus my attention closer to where I work than where I live. Thanks for that.
TR4nut
Here's a possibility from a quick web search:
Leyland WS key blank
oops, sorry didn't read your note thoroughly enough - I see you've found them already at this price..
tomgt6
Just look in the local yellow pages under locksmith. I have two in town who will cut new keys for about $4 buck a piece. One of the locksmiths has just about any type of key I have ever looked for. A good smith will have a great inventory of blanks. They are not fancy banks but what do I care. I don't need to look at them while driving.
Don_R
Doug,
If the locks are the same as a 73 1500 you might try
KEY blank MZ12
The keys that came with my 73 are Mazda keys
COLE Blanks MZ12 D80K
Fits Mazda
that is what is stamped on the keys...
hope this helps
TR3driver
Here's a better price on WS blanks:
Triple-C.com
Looks like I've got 3 of them, two Silca DM1R and one ILCO FT6R ... make me an offer.
Good luck with the "old time locksmith". I called one some 30 miles away who assured me he had blanks for my Stag ... when I got there he changed his mind. Good thing I brought some with me
dklawson
dklawson
Thanks again all.
I found an Ilco PDF catalog and an online vendor whose information crosses/matches all the information shown in Randall's last link and the Mazda information posted by Don.
Also available from here:
https://www.sunshinelocksmith.com/catalog...p;products_id=2
With that information I'm going to check locally first. All these options at roughly $5/key (plus cutting) are better than the $15 from the regular British parts sources. However, I will pursue local old-time locksmiths as well.
Thanks again to everyone for the information.
swift6
I know the local Ace/True Value Hardware stores will cut keys for free if you bring in the blank. Might be worth checking out in your area.
dklawson
dklawson
No local lock shops or hardware stores had the blanks. The places that are likely to have the key blanks are only open 8:00-5:00 M-F and are not at all convenient to where I work. I decided to order the blanks online from the company I posted the link to in my last post. Free shipping and $2.70 / blank. The local True-Value hardware said they will cut the keys for me if I can supply the blanks. I ordered 4 so I should end up with one or two good keys even if they make a mistake cutting them.
Thanks again to all who posted suggestions.
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
K TR2/3/3A Ignition Timing? Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
O Sprite Petronix Electronic Ignition Spridgets 10
