Ignition advance weights - how to lube?
John Turney
Pull the rotor off. I think there is supposed to be a felt disk there. If not, you'll see a screw head. A drop of oil there.
dklawson
Lubing the spindle as John described above is the most routine maintenance for the advance mechanism. Oil applied to/around the center screw wicks down and allows the top half of the spindle to move relative to the bottom half (allowing the centrifugal advance to take place). To lube the bob weights and springs is a bit more involved.
Remove the distributor cap and rotor,
Disconnect the breaker plate to distributor housing ground wire if fitted,
Remove the screws securing the breaker plate to the distributor housing,
Remove the breaker plate.
With the breaker plate out of the way you will be able to see and lubricate the bob weights and springs.
Apply a few drops of engine oil at the pivot and contact locations.
As Haynes says, reverse the steps above to reassemble. However, when done, check your points gap and timing. Also apply a thin film of light grease to the distributor points opening cam (or if your points have a felt wick, make sure it is completely wet with engine oil before you fit the cap and rotor). Failure to lube the points cam can lead to very rapid wear of the heel block on the moving arm of the points.
You asked how often to lube the bob weights and springs. I don't remember seeing a time specified but it wouldn't hurt to do it every few years or so. Just be careful not to lose the distributor's screws.
steveg
I made these marks so it's easy to remove the distributor and get it back in exactly the same place. I usually take a phone pic like this before the R&R. Belt-and-suspenders.
Doug's service steps per above are easier carried out on the bench and one's less likely to drop one of the little screws into oblivion.
T MGB Vacuum advance and Electronic ignition conversion MG 5
S ignition advance curve 25d6 Austin Healey 10
N Ignition advance??? Spridgets 29
J Ignition advance with Weber DCOE Spridgets 7
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 9
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
K TR2/3/3A Ignition Timing? Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
