Ideas for an Alloy Racer
MikeAH100M
I have a top-notch mechanic friend who just acquired a basket case BN2. He's rebuilding the car from the frame up and was recently able to acquire an all alloy body. So his idea is to create a light racer. My question to the forum, what mods would you recommend to him? He is an exotic car mechanic and restorer so cost and skill are not an issue. I've suggested an alloy head, the LeMans cold air box/carbs and front discs (he may go discs on all four corners). What else would you add when the sky's the limit?
Thanks
Mike
PS: He's thinking about leaving the body bare polished which I think would be cool to see. His goal is to have the car done by next year's Pittsburgh Vintage Grand Prix.
A long time ago I read an article by a 100M racer; he said he'd done dyno work that showed the car had more HP with velocity stacks instead of the cold air box. That makes sense since with the box air has to make a sharp 90deg turn, which more than negated the effect of slightly cooler air.
BBH
If staying 4 cylinder could he not put in a 100S spec engine. Alternatively he could stay with the alloy theme and put in one of the aluminium 6 cyl engines available which would give quite a bit of weight reduction.
wangdango
We have campaigned a '56 100 Le Mans for many years until the birth of my daughter and racing went on hold. I can tell you, the cold air box in theory works, (ram air), however really good free flowing air filters work better. Another thing that the 100 engine really likes is a exhaust pipe all the way to the rear of the car, the back pressure is a benefit. We have headers, and run a 2 1/2" straight thru exhaust with stubby supertrap on the end, (made it up with a stubby supertrapp and cut off the smaller pipe and tig welded a bigger one. Most of the time can run the car without any of the disks/baffles. Just my 2 cents. Our car is also all alloy except the door skins and the boot lid, (have an alloy door skin and an alloy lid, just have not got around to fitting it). Keep us posted on the project!
dougie
If he's interested in making a real vintage racer, one that he could ultimately sell as a "turn key" ready to race car that would be accepted by most sanctioning race organizations, he'll need to do his home work. I love the idea and always preach to all who'll listen, GET YOUR HEALEY ON THE TRACK.
https://www.svra.com/wp-content/uploads/2013/02/Austin_healey.pdf
MikeAH100M
MikeAH100M
Thanks for all of the suggestions and for any others that pop up. I hope to get some "before" pictures this weekend and will keep the forum posted on progress.
BN2guy
I would think that before your friend makes any modifications to his BN2, he would be wise to check with the race organization to determine what modifications are allowed for cars in the class in which he intends to participate. That's the first part of doing the homework. If he's interested in true vintage racing, he will probably be limited to only those modifications that were allowed back in the day.
Personally, I really enjoy seeing Healeys in vintage races. So, I wish him nothing but good luck.
HealeyRick
This isn't a serious suggestion but more in line with what I'd like to do if I had unlimited funds. Looking at the 100S register shows that 7 or 8 Ss had V8 conversions and at least one, AHS 3505, competed in SCCA C/Modified which had a limit of 5000ccs. https://www.northernhealey.co.uk/austin_healey_100s_history.php I'm guessing the motor was probably a 283 Corvette motor. I'd love to see a 100S replica configured this way to compete in vintage racing against some of the early 289 Cobras with their leaf spring front suspension. It would be fun to see a Healey racing with the big iron of vintage racing. although Frankenhealey's car comes pretty close: https://www.britishv8.org/Other/IanOsborne.htm Even though these were modifications done in period, I don't think a vintage racing org would admit such a car.
BoyRacer
Hey HealeyRick, It may be fun to watch a Healey racing with Corvettes and the other big dogs from the bleachers ....... but sitting in the pilot's seat in a Healey while on the track with those monsters is not for the faint of heart. A couple of points. They out-weight a Healey by almost 1000 pounds. They sit a bit higher and don't see you so well. They slide through the turns more violently that you do. Because they're bigger than you they use their size to intimidate you so you won't attempt to make a pass in the turns ....... similar to blocking but not as blatant.
The good thing is that the early Corvettes (the ones that race with Healeys in some organizations) have drum brakes. And, as the race goes on, and because they are heavier, their brakes start to fade and their tires start to go away, and then we can pass them under braking. Yeah Baby !!!!!
dougie
When developed to to the highest level and driven with great "anger" the big Healey can dominate.....
BBH
Well that had a bit of every-thing, shame the BRG healey was wiped out by the lightweight e-type.
What sort of power was Marc's car putting out? Also from what looked like a lot of late braking into corners, I am guessing that his brake set-up had a bit more bite than normal..
DerekJ
Based on what I know from other UK racing Healeys I would guess Marc's car is putting out around 275bhp. It hasn't been out racing for a while, not sure why. Hopefully we might see it at Castle Coombe next month in the all-Healey race. The green Healey that was hit by the German E-Type is raced by Chris Clarkson. It also suffered some heavy damage in June this year at Silverstone. Hopefully it will be ready for Castle Coombe
B Cove Paint Color Ideas Austin Healey 10
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
nathandarby67 Ideas for organizing hardware when plating Restoration & Tools 6
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
Sarastro General Tech Any good ideas for removing liners? Triumph 20
Sarastro TR4/4A Any ideas for repairing jack damage? Triumph 13
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
Rut TR4/4A Shop with lift ideas Triumph 21
maxwedge5281 third brake light ideas Austin Healey 34
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
M General Tech Creative ideas, shop equipment, fabbing techniqes, etc Triumph 0
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
trotti Stuck drum - any ideas? Austin Healey 5
CJD TR2/3/3A Engine Storage Ideas Triumph 2
T TR4/4A Lowering my TR4a - ideas? Triumph 18
catfood Any Ideas? Austin Healey 7
aeronca65t Christmas Card ideas Other British Cars 5
RickB Any temporary Bugeye grille ideas while I send mine off? Spridgets 16
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
RJS Top Frame Repair - ideas needed Triumph 8
Mychael Ideas for a parcel shelf in a Frogeye Spridgets 8
T ideas on fixing - one carb keeps "rusting" Triumph 4
I TR6 TR6 difficult to start - ideas? Triumph 6
M Any Ideas Triumph 26
K Any ideas for a Handbrake Warning Light??? Triumph 11
bighealeysource ideas on how to fix dents on frame Austin Healey 15
Darrell_Walker Alternator cleaning ideas Triumph 10
ahealey1004 bn4 drum brake issues...any ideas? Austin Healey 7
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
M 948 vs 1275 - Looking for opinions and ideas Spridgets 34
Brosky Upholstery makers in England? Any ideas? Triumph 21
T Ideas on fixing this? Triumph 19
eschneider leakdown test readings - ideas? Restoration & Tools 12
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
A TR4/4A TR4 mistery engine problem - any ideas Triumph 14
startech47 Any ideas? Spridgets 8
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
T Ideas on getting this bolt unstuck Triumph 42
RickB New steering wheel, ideas about adapting? Spridgets 23
bighealeysource Ideas on where to get ID plates stamped Austin Healey 3
M Need Engine Swap Ideas for '76 Midget Spridgets 21
T TR2/3/3A TR3A vibration - looking for ideas Triumph 38
RickB Ideas about modifying seats to fit rollbar? Spridgets 6
R front emblem rehab ideas??? Triumph 16
scubabatdan Ideas on cleaning a yellowed rear window? Spridgets 1
