TR2/3/3A How to attach rear seat tabs to anchor the seat back???
Jerry
The rear seat has three tabs on it. I can guess that the bottom ones must attach to the floor, but where does the middle one at the top attach? And how do you do that attachment? from the front with the seat turned upside down?
Any hints appreciated.
Jerry
1960 TR3A
mgedit
Jerry, not sure if your car is same as my 56, but I was stumped for a while too. I ended up securing the bottom to the brackets and the back rests against the vertical part of the seat bracket as I could not figure out a way to make a permanent connection. I made some brackets at top on each side to secure back and these are out of site under capping. Some pics here:
https://www.triumphowners.com/collection.cgi?task=PHOTO&photocategoryID=2294&sectionID=111032
Can try to find more pics if needed.
Cheers, Mike
Lbp
Ah, a foil side up man! Just had this discussion on another thread. I hope to complete my interior this weekend, though I've thrown in with the foil side down crowd. Hope mine comes out as nice as yours.
Bayless How does '67 Sprite top attach to body? Spridgets 3
R General Tech How to attach pic's to a post? Triumph 1
C How to attach escutcheon retaining plate to the escutcheon? Austin Healey 2
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
M TR4/4A Where does this attach? Triumph 7
Mychael Bonnet hinge. How do they attach at firewall. Spridgets 3
B TR2/3/3A Pulling engine & trans on TR3B - hoist attach? Triumph 6
N How to attach latch to top bow, AH100-6 BN4L Austin Healey 2
I How to attach a British plate - help please. Spridgets 7
58Custom How to attach a rotiserie? Spridgets 9
R TR4/4A how does choke cable attach at Carb 65 tr4a? Triumph 6
B Nothing to see here,pic attach attempt MG 7
B learning to attach a pic. MG 18
Bruce_B Datun 5 speed--where does the Speedo cable attach? Spridgets 26
R attach a file in a posting? FORUM Navigation Questions 1
L Engine stand: how do you attach? Spridgets 12
RickB How to? Attach fiberglass teardrop to metal hood? Spridgets 4
RickB Got a NOS "grille finisher" - how does it attach? Spridgets 13
longbridgehealey oops - forgot to attach e-bay listing Austin Healey 2
J Spitfire '70 Spitfire MK3 - Where does this attach? Triumph 10
X How to attach more than one picture MG 3
T Where do I attach a tow line for emergency tow ? Triumph 6
Steve P. TR4/4A TR4A: w/s to convertable top attach? Triumph 4
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
