Horrible Freight MIG Welder???
Patton
I want to learn to weld and I want a welder. I don't have much money to get into this. Harbor Freight has just put one of their MIG welders on sale for $174.99. That is in my range! I also know that their stuff can be junk.
Here is the info...
87 AMP, 115 VOLT FLUX AND MIG WELDER
For mild steel, stainless steel, and aluminum. Weld with gas or perform flux cored gasless operations.
* Welding current range: 25 to 87 amps
* Input: single phase 115 volts, 60 Hz
* Open voltage: 19 to 30
* Duty cycle: 20% @ 75 amps, 45% @ 50 amps
* Draws 21 amps @ 120 volts
* Weldable wires: 0.023'' to 0.035'' steel and stainless steel, 0.030'' to 0.035'' aluminum, 0.030'' flux-cored
Includes: 2 lb. spool of flux cored wire, handheld face shield, brush hammer, fuse power line; Weight: 55.8 lbs.
I know that a certain percent of people on this forum will say about always buying the best, but this is about the best I can afford, is this "pile of junk" worth the risk?
Patton
aeronca65t
I have this welder....I bought it a few years ago on a whim and haven't really used it that much.
We have a "better quality" Lincoln portable MIG welder at work and I use that once in a while. It's about the same size as the HF unit and cost about twice as much (not including the gas bottle attachment that we added later on).
I'm not really that keen on either of these little 110V AC MIG units for welding regular steel. And I'm not keen on the gasless wire (flux core). Doesn't work that well and the fumes are hugely toxic. I've used the Lincoln to weld aluminum and again, I'd say it's OK but not great....keeping the aluminum wire feeding smoothly is a challenge, even with the teflon insert.
A buddy of mine has a large MIG welder that I much prefer (but it probably runs close to $2000 new).
I have an old 220V AC stick welder that I use quite often. For angle iron, fixing trailers and so forth, it works great.
For thinner steel, I use a small set of oxy-acetylene tanks that I bought from HF. I like oxy-acetylene welding and can do a decent job even using unpainted steel coat hangers as a filler rod. The tanks don't last real long but they are very portable so I accept the compromise of size (and I have access to a full size set of tanks at work for bigger jobs). With the tanks, it's also possible to braze, cut, solder and even mend cracked aluminum (using a zinc rod).
For lighter stuff, I'd buy the tanks (maybe bigger than my mini-size, though).
For heavier stuff, I'd buy a 220V AC stick welder. Sometimes you see decent used ones on e-Bay.
screenprinter
I agree with most of what aeronca65t said - But it depends on how deeply involved you're planning to get - If you're just going to do the odd repair on sheet metal, a little bodywork, etc. or light duty work around the house the little mig setup should be sufficient - Like the man said - Stay away from fluxed wire - a real bummer - spend a little extra and get the shielding gas bottle - this will help you immensely. You can always upgrade at a later time should you fall in love with the process and figure you need more, bigger, better, etc.
If on the otherhand you're going into it with a vengeance I would buy the best you can afford - you get what you pay for...
Just a note - we have a Harbor freight nearby and I've gotten some pretty good deals from them - In particular an Auto-Darkening Welding Helmet for around 60 bucks - for a novice welder this is a great thing, not having to line up your gun and then flip your helmet down, which invariably moves your gun off target.
Whatever you decide, good luck and have fun!
Bruce Bowker
Stay away from cheap welders. Get a brand name.
Bruce
frankenstang57
/ubbthreads/images/graemlins/tongue.gifIf I were you, turn around and run away screaming. The Harbor Fright welders are terrible! You'd get as good of results if you hooked a pair of jumpercables to a battery and arc'd it with a coathanger. /ubbthreads/images/graemlins/grin.gif Not that I hate HF, I'd considered their welder at onetime too, but they are crap! I have used a few of the smaller 110 welder and have had pretty decent results, before buying a 220. One was a little Lincoln. It suprised me with how well it worked compared to a Craftman one I had also borrowed. I finally went with a Hobart 180. I think it cost me around $820 out the door. It's probably more welder than you need though, and alot more money as well. I'd look into Hobart welders. They are made by the same company who makes Miller. The biggest difference I found between the Millers and Hobarts are the voltage controls, the Millers being infinate. Things to look for; voltage control adjustability, can you run gas with it, how many amps, and what are going to be using it for. On cheap welders like the "Chicago Electric", they may give you one or two "heat settings". Well that's fine if you are welding the same exact thing over and over. The more adjustability you have the better. My welder has like 5 settings, and with wire speed adjustments it can be tweeked to to weld from sheat metal to 1/4" plate. Of course the ideal would be to have infinate voltage adjustment, which is what the $$$ welders have. Having the ability to run gas with the welder is a must. The flux core wire splatters like a mutha! Gas is sooo much nicer. The flux core wire was designed to be used outside in windy conditions where the sheilding gas would be blown away. In your garage, you don't need it. Duty cycle is another concern. It refers to how long you can continously arc. Here again, the higher # is better. If I were you, shop around abit. Anything from Miller, Hobart, or Lincoln should suit you fin. I'm not sure who makes the Sears one, but they work allright too. Another thing I'd recomd is talking to you local welding shop. Mine was pretty helpful. I paid a couple of dollars more(literally) than on line(get an idea how much they are), but now I have someone to help me out if it breaks or gives me trouble. Sorry about the rant, 'just went through all this myself! Spend the extra $100 os so and pick up something decent. So screenprinter , you like the HF auto darkening helmets? They are on sale right now for $39. Might hafta pick one up! /ubbthreads/images/graemlins/tongue.gif
Mark Jones
Check at Home Depot. They carry Lincoln welders I believe. I have a Hobart 130 (I think that is the right #) 120V machine and really like it; that and my auto-darkening helmet.
RobSelina
they're junk. I had one and I thought I was just inept at welding until I finally caved and got myself a milermatic 175. Then I realized I wasn't the problem.
At the very least, get the entry level lincoln 110V unit with the shielding gas attachment. Flux core units work, but you really want an Argon/CO2 shielding gas to do anything 'pretty'. Flux is hard to use on thin metal too. If you get anything less than this it'll be a paperweight that won't get used. Ultimately, a lincoln/miller/etc 220V mig is the way to go, but a lincoln 110V gas unit will get you a long way...
DornTRoriginal General TR Up-date Horrible Car Restoration Saga Triumph 3
M TR2/3/3A Horrible tr3 for sale Triumph 0
E Ghastly, horrible cars, but why do I own one? British Motor Corp 5
E Ghastly, horrible cars, but why do I own one? British Motor Corp 0
simpzimmer Horrible sound! Triumph 4
P This is horrible. Spridgets 15
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
steveg Harbor Freight jack stand recall Austin Healey 7
TomMull Harbor Freight "Earthquake" impact wrench Restoration & Tools 10
M TP Tools vs. Harbor Freight Restoration & Tools 12
D Harbor Freight Inline Air shears Restoration & Tools 14
steveg Canadian Equivalent to Harbor Freight Austin Healey 3
Rut Harbor Freight Spridgets 0
Rut TR4/4A Harbor Freight Triumph 2
Rut Harbor Freight/Tractor Supply Spridgets 4
bighealeysource Harbor Freight mig welder Restoration & Tools 1
tahoe healey New Harbor Freight floor jack Austin Healey 5
M Harbor Freight Restoration & Tools 42
L Harbor Freight Rolling Tool Cabinet Restoration & Tools 31
G Harbor Freight Car Dolley Restoration & Tools 2
Brosky Harbor Freight Tools New Years Day Special Triumph 5
tony barnhill Harbor Freight Tool Deal Restoration & Tools 13
DNK Harbor freight Triumph 14
DrEntropy HYLOMAR at Harbor Freight! Restoration & Tools 8
tony barnhill Harbor Freight Sale Restoration & Tools 33
tony barnhill Harbor Freight Parking Lot Sale... Restoration & Tools 27
eejay56 Tool rolls at Harbor Freight Restoration & Tools 22
L Went to Harbor Freight Restoration & Tools 4
jlaird Harbor Freight again Spridgets 2
jlaird Harbor Freight came to my house Spridgets 10
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
TomMull Question on MIG wire feed Restoration & Tools 7
T Will this work on MIG welds? Triumph 10
1965_MGB MIG Welding Anyone? Restoration & Tools 8
T TIG or MIG Triumph 10
Jim_Gruber MIG Welder Wire Size Spridgets 20
BritCarFan 110 or 220 Volt MIG welder Restoration & Tools 18
Thor Any Suggestions on which Hobart Mig Wleder? Restoration & Tools 2
eschneider arc-brazing or mig-brazing Restoration & Tools 3
budk1953 Opinions Please-Mig or Stick Restoration & Tools 19
mrstinson Welder Recommendation - TIG or MIG Restoration & Tools 15
Y Welding [ Techniques: TIG vs. MIG ] Austin Healey 7
S HTP VERSA MIG Restoration & Tools 8
M MIG welders Restoration & Tools 17
