I've done that, and what is stated above would be good advice. Here are some of my thoughts:
You're far into things if the heater is being pulled. I'd take advantage of having things apart and remove not just the dash support, but I'd actually go ahead and check all the wiring and other possible "mess" under the dash. If you see any rust, burnt wires or other such items, I'd remove all the gauges and then the dash as well.
I'd solder/fix/re-tape all wires as needed, clean all connections, replace bulbs where needed, and use a thread chaser or tool on any dirty or rusted captive nuts or other fittings.
This would be a great opportunity to replace any cracked dash pieces, the plinth or other problem areas.
With all that out of the way, dropping the heater out is a cinch, but be sure you drain the radiator and use that towel as recommended above. Might as well buy a new hose junction at the firewall. Those are frequently rusted and very weak. New heater hoses are important, and like Geo says, be sure to take pictures. Even those two hoses get tricky how they twist around each other.
Remember, you can't remove that top dash piece without removing the windshield and that is not so hard. We can help if you're interested in more advice.
Like glemon says, there are just a few bolts holding the heater up there, but there is a big rubber gasket at the dash, and you can order one or just make your own. Don't over tighten those bolts or you could strip the captive nuts. I think the rubber bushings might be ordered from Moss. Again, because of the wiring, and since you'll be disconnecting for the heater, it just makes me think you might opt to remove the whole dash and really do a number fixing things up. Sounds like overkill maybe, but I sanded rust spots and treated with RustMort, then spray painted, too.
Be careful not to break the plastic channel hose to the ducts, or the ducts, themselves.
Careful not to break the soldered bracket hanging down from the heater for the radio. That thing comes in handy. Good time to install a radio, too, if you care.
Sorry, got carried away. Your question was easier. thx
