General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . .
KVH
Is there a reason that the cables are "crossed" behind the center control console? Why doesn't the heater vent one go directly from the left console hole, and the heat volume control directly from the right hole? A random guess: The designers felt that by having the cables longer and crossed the users could better manipulate them for space behind the console, which is a bundle of wires anyway? Some more obvious reason?
CJD
That must be a TR4 thing. The TR2/3 don't use cables, but rather electrical blower wires and manual heater flappers...except for the center vent that runs straight in the dash and doesn't cross anything.
Popeye
Bronze
Could it be to reduce bend radii?
(I’m not there yet with my rebuild…)
Sarastro
Interesting question. I had not noticed that, and logically installed them with the vent control on the left and heat control on the right. I just checked the manual and indeed they are as you say.
I will say that, my way, the vent control cable is a little too short for convenience. The sheath of mine actually cracked near the clamp on the heater body--but that might have been my fault, as I restored the cables myself. As for the heater control, I can't see any advantage to having it on the left. Perhaps this arrangement gives you a little more room if you have to remove the console, but I don't see a lot of evidence elsewhere of design for easy repair access.
losmorob Heater/fresh air vent on an early '67 Spridgets 1
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R TR6 Heater control bezels TR6 Triumph 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
6 Smith heater rebuild Austin Healey 8
Healey Nut Heater Box Installation Austin Healey 4
CJD TR2/3/3A Heater Delete Triumph 15
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
F TR6 Heater Triumph 7
C Water flow in heater? Austin Healey 5
C Heater knobs won’t stay on... Austin Healey 4
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Austin Healey heater assembly Austin Healey Classifieds 1
C TR6 Heater Removal Triumph 2
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
F Heater valve/tap gasket- Install dry? Austin Healey 10
F Heater pipe and air duct routing BT7 Austin Healey 3
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
L TR2/3/3A Heater ID Triumph 5
F Help need reinstating my heater - BT7 Austin Healey 7
C Testing heater core Austin Healey 9
S TR2/3/3A power wirer for the heater switch Triumph 16
glemon Shop Heater Restoration & Tools 17
D Smiths Heater rebuild. Restoration & Tools 1
D TR2/3/3A Smiths Heater rebuild. Triumph 2
Got_All_4 TR6 Heater upgrade Triumph 6
Michael Oritt Heater motor or switch problem Austin Healey 1
B TR6 Heater controls stiff Triumph 4
edkap2002 TR6 Heater Control Valve Triumph 9
