HD8 Carb Set Up and Adjustment
fwtexasbj8
Hey guys, I need help again getting the old girl back running well after not being driven much for the past few years.
I recently rebuilt my BJ8 carbs and since, I seem to have very little power and the engine seems sluggish. I have gross jets in the floats and when I get the airflow the same and the jets adjusted, the tops of the jets are between .125 (front) and .165 (back) below the jet bridge. I have removed the float covers (again) and adjusted the float levers to 7/16" per my service manual but when I look down into the jets, it looks like the fuel level is 1/8-1/4 inches below the top of the jets. The car was idling good up until recently when I am starting to see some decay as it gets hot. I am convinced the timing is good and I checked the valve rocker clearances when I had the cover off last weekend and they were all good.
Does anyone know approximately where the top of the jets should be relative to the bridge and how far below them the fuel level should be? I have read the fuel level should be "just" below the jet top but am unclear how far. Do the gross jets have any effect on float lever setting?
When I rebuilt the carbs, I verified the needle diameter but it has a tapered neck without a clear indication of where it should be installed flush with the bottom of the piston. I did my best to set it right where the needle starts to taper and then was careful to set the other one with the same amount below the piston. Does anyone have a better way to set tapered needles?
Finally, any other tips to correct the lack of power? I really think it is carburation since the car had good power before the carb rebuild but have about tapped out my guesses.
Doug
There are two variations of needles: one with a "shoulder" where the tapered length meets a straight length and one with a groove (most common in rebuild kits). With the shoulder type, the needle should be fitted into the piston such that the shoulder is even with the bottom of the piston, with the grooved type the BOTTOM of the groove should be flush with the bottom of the piston (counter-intuitive to me, but correct).
I use Grose jets, and adjusted the arm so that the jets were closed with the proper clearance (7/16"), just like you would with a needle valve. This adjustment is critical.
Working from memory--I couldn't find a reference in my SU tuning guide--the main jet should be between 1/16" and 1/8" below the venturi bridge (sounds like your back jet sits too low). The fuel should be about 1/8" below the top of the jet.
Did you center the jets? If the needle(s) is(are) dragging it could cause your symptoms, but my guess is the rear carb needs the float level adjusted.
BTW, why did you rebuild the carbs if the engine had "good power" before?
F
fwtexasbj8
Bob,
I did center the needles and they still seem fine today when I checked them. I originally rebuilt the carbs because as I was trying to adjust them, I noticed the jet bearing screw had become loose and the rear jet was very loose in the bore.
Doug
J Wanted HD8 SU carb set Austin Healey Classifieds 6
AUSMHLY SU HD8 carb set Austin Healey 6
M New Member with an HD8 Carb Question Austin Healey 1
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
D HD8 Carb. Value Austin Healey 7
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
J HD8 carb adjustments ? Austin Healey 6
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
G HD8 Idle Adjust Screw Austin Healey 10
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
wangdango Colortune for HD8 Carbs? Austin Healey 55
B mysterious leaking of SU HD8 Jaguar 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
D S.U. HD8 Carburetor Drawing Austin Healey 6
S Float valves for HD8 - Grose Type Austin Healey 20
steveg HD8 high idle aggravation Austin Healey 11
AUSMHLY HD8 pin & spring assembly Austin Healey 6
C Hd8 su fuel lines Austin Healey 2
D Rebuilding the SU HD8 carbs Austin Healey 24
pkmh HD8 SU Carburetor removal Austin Healey 48
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
S Float Level for HD8, BJ8 carbs Austin Healey 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D K&N filters for HD8 carbs Austin Healey 26
BOBBYR HD8 Carbs Austin Healey 2
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
A BJ8 SU HD8 carbs for sale Austin Healey 0
J HD8 shaft bushing & king pins. Austin Healey 6
R Setting up HD8 carburetors Austin Healey 6
