Grounding Side Lights
rossco
Wires in side light loom, red, tracer wire, black. If the black wire (ground) attaches to the base of the bulb unit why is it necessary to ground the whole lamp to the frame with the three sheet metal screws?
Keoke
Generally this is done to protect U
If the GND wire were to break and fall against the lamp frame it is desired that any protective fusing provided for the circuit would be activated:
Hopefully , preventing any damage to the car's bundled wire harness.
Which might initiate a fire.?
R
rossco
The reason for my ? I'm finding the reason it's so difficult to install the side light is the sheet metal screws tend to hold the overly thick bulb cover too proud for the retainer ring to slide under the rubber grommet ring. I tried leaving the screws out and the rest was a piece of cake. A slightly thinner lip on the glass cover makes sense to me. But Lucas didn't ask.:smile:
BigGreen
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
R TR2/3/3A Grounding problem Triumph 21
S TR2/3/3A grounding the voltage regulator Triumph 14
D TR6 Rear lights don't work. Grounding Problem ? Triumph 14
TulsaFred Dash harness grounding Spridgets 5
P Headlights and Turn Signal Light Grounding Spridgets 3
P Grounding of Horn Push-Bugeye Spridgets 4
I Bugeye grounding strap help please Spridgets 6
R Grounding Triumph 4
memphis Dash Gauge Grounding Austin Healey 7
6 Fuel Pump Grounding Austin Healey 12
I Negative grounding questions Spridgets 12
doughairfield steering column grounding strap Triumph 6
drooartz Of horns and steering column grounding Spridgets 16
I Bugeye grounding 101 Spridgets 13
T Help finding grounding clips Triumph 6
R MGB Poor grounding license plate lamps 67 MGB MG 13
vping T-Series Silly question on TD Grounding MG 12
19_again question about shorts/grounding MG 19
M Trunk harness grounding location BN4 Austin Healey 4
wkilleffer Under the hood grounding point MG 11
K Radiator Care / Grounding Restoration & Tools 1
K TR2/3/3A Side view mirrors again Triumph 8
roscoe Side Curtain Hardware Austin Healey 2
G Right-Side Shock Weeping Oil Austin Healey 1
Walter74 AH Spares Side Exhaust Austin Healey 2
R MGB side chrome installation MG 4
W Need advice on installing new side curtain glass Spridgets 1
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
kodpkd Side Curtain Windows Austin Healey 11
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
D Rear Seat Side Panels, BT7 Austin Healey 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
D BT7 Rear Side Panels Austin Healey 0
T MGA Unknow side screen MG 6
K TR2/3/3A "Clip on" style side mirror? Triumph 9
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
S For Sale Side Screen Anchor Plates Triumph Classifieds 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
R bugeye side lights. Spridgets 0
R side light install Spridgets 2
HealeyRick BJ7 Side Window Alignment Austin Healey 31
Fanch00 Noisy Side Screens Austin Healey 13
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
