Grease zerks for rack and trunnion
Norton47
I am trying to do the lube maintenance for the 6. I got the rack lube by using a 1/8 inch zerk but it is really pipe thread so I just started it and got the job done.
But the trunnion seems to be 5/16 inch. Are these straight thread or British Pipe or ?
Where can they be obtained?
Also the rear drive shaft ujoint zerk seems to be impossible to fit the gun to due to minimum clearance between the ears.
Any tricks here. Old posts talk about not greasing at all and using Spicer parts. Whats a guy to due until he needs to replace joints?
TR6oldtimer
The grease fittings can be obtained from Moss Motors
and probably others like TRF...
N
Norton47
Thanks, True, but this only seems to cover the ball joint and the steering rack and the vertical link. Nothing about the trunnion. I was also trying to figure out the actual thread style. Bikes use British standard fine or BSP, etc.
TR6oldtimer
The trunnion is lubricated by the zerk on the lower part of the vertical link. Whether it is grease or oil, the lubricant passes down through a passage in the vertical link into the trunnion. The trunnion to the lower wishbone does not have a provision for lubrication.
Alan_Myers
Hi Norton,
The trunnion zerk is a fine pipe thread, if I recall correctly. I found them easily at a local auto parts store (just bought a package that had a selection of sizes in it, and one of those worked, so I'm not able to tell you the size for certain... 1/8" ISTR).
Also not totally sure if it's BSP thread or not, almost certain it's not. But it doesn't really matter. British pipe thread and US pipe thread are so close, either will work. In fact, I've often seen USP deliberately mixed with other BSP threaded fittings on cars, because the slight interference fit makes it less likely the fitting could ever rattle loose.
Yes, the grease port on the top of the R&P has a straight thread, not a pipe thread. I have a couple modified zerks I made up for use there, simply by carefully re-cutting their threads with a die. I seem to recall it is 3/8" x 24 (NF) thread fitting. It's impossible to cut the new threads all the way down to the shoulder of the hex, but even so the zerks work fine for the occasional lubing of the R&P.
[ QUOTE ]
[/ QUOTE ]
True on TR6. But, actually, there are grease fittings for these on TR4 and earlier, which have honed bushings running on the horizontal steel pin.
OTOH, TR4A and later cars with the nylatron bushings and large "bolt" don't get greased.
N
Norton47
Gottcha the location of the zerk of the trunnion was throwing me off. The verical link zerk is in place and I have lubed it. Sounds like I am off to the next project.
Thanks
martx-5
[ QUOTE ]
Also not totally sure if it's BSP thread or not, almost certain it's not...
[/ QUOTE ]
I took the trunnion and upper ball joint fittings out of my TR3, and measured them. They are 1/8"-28, which is BSP pipe thread. Yankee pipe threads are 1/8"-27 (NPT). Of course, this is on my TR3, other models may be different. As you state Alan, the 1/8"-27 is so close, that in this application it will not make a difference. In some applications it will make a difference. On my Miata, the oil pressure sensor is threaded with the British 1/8"-28, and if you put in a sensor that is 1/8"-27, it will leak.
guzzul
The rear drive shaft u-joint zerk is indeed hard to get at.
The drive shaft flange, however, is not symmetical. If you look hard at the drive shaft u-joint flange, one side of each flange 'ear' has a concave curve in it to allow just enough space to get a grease gun nozzle into. The other side of the 'ear' is straight.
When the u-joint is installed, you need to ensure that the hole for the zerk fitting is facing forward (i.e. toward the front of the car), and ALSO that the u-joint is oriented so that the zerk will stick out on the drive shaft side that has the curve. If that wasn't done when the u-joint was fitted, you won't get at a standard zerk.
Unfortunately, I have learned this from experience.
The only other thing to suggest regarding the drive shaft is to install a 'needle' zerk fitting. You can get them at NAPA. The needle zerk is a standard fit (1/4"-28 pitch I believe), and has a minimal-clearance flat head. You can get a needle fitting for the end of your grease gun, and presto, you can get at the fitting.
guzzul
FYI, the Napa number on that flat-head zerk is PUJ621. They don't show a price on the NAPA website, and they indicate it is an in-store item only. I have got them from an auto-parts dealer here in Canada, but Napa Canada said they couldn't get them.
I have attached a picture from the NAPAOnline catalog.
As a suggestion, you might think about using a hacksaw to cut a straight kerf across the top of the zerk so you can use a flat screwdriver to snug it down into the u-joint. I found that even the flat zerk was tough to tighten down against u-joint, since its hard to get a socket in there.
C TR2/3/3A Grease Zerks Triumph 7
S Plugged Grease Zerks Spridgets 7
M Grease Gun and Zerks Triumph 11
J Grease zerks MG 2
L Red Rubber Brake Grease Austin Healey 2
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz What am I seeing - oil/grease on wheel Spridgets 20
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
Jayplum TR2/3/3A Grease cap Triumph 25
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
AUSMHLY Grease type for zerk fittings Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Grease Gun Recommendation? Spridgets 7
steveg Recycling grease question Austin Healey 11
R grease for windshield wiper motor- BJ7 Austin Healey 4
D TR2/3/3A grease nipple/zerk Triumph 6
S TR4/4A how ro grease steering box? Triumph 4
C General Tech Grease and Grease Gun recommendations Triumph 12
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
N Lockheed brake assembly grease??? Spridgets 2
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
P TR6 Grease job Triumph 6
Popeye TR4/4A Stub axle - grease or no grease? Triumph 4
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
M Oil Gun vs Grease Gun Spridgets 21
tahoe healey dielectric grease Austin Healey 13
S How much grease for the drive [prop] shaft plunger Austin Healey 3
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
S Will copper grease work for squeeling brakes? Austin Healey 3
charleyf TR2/3/3A Rear axle grease Triumph 0
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
R TR2/3/3A Grease fitting list Triumph 5
simon1966 Current day grease choices? Austin Healey 3
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
RJS General TR U-Joint Grease fitting interferes Triumph 4
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
AUSMHLY Distributor grease Austin Healey 2
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
K TR2/3/3A Trunnion oil/grease again? Triumph 1
brohawk TR6 Grease on rear hubs Triumph 8
S TR2/3/3A grease in tr3 D2 wiper motor Triumph 2
