MGB-GT gassy carbs
Sopwith_Camel
well I'm close the carbs SUs type HIF4s are idling high. but I'm not stalling out.
today it was warm enough I could get the choke off yes its 49 degrees in mid norway.
I have the jet adjustment screws about two turns down.
the issue is Im bogging down on the test drive when I give its some "welly" at about 2500rpm
Question so less gas with the idle screws or with the needle jets adjuster?
tomorrow is to be 4c so I have another shot at this, but only 4.5 hours of day light. I do need to get the power on to get up the hill to the house.
PAUL161
Two things to think about, make sure the dampers have oil in them and make sure the floats are not set too high. Are the butterfly discs opening equally, meaning one is not leading or lagging the other? Are your air cleaners original, are they clean? Some after market air cleaners are too restrictive and can cause a rich mixture, if you have after market air cleaners in your situation the best way to check is to take them off and run the engine without them for a test. Just throwing a few things your way, maybe one will help. PJ
Sopwith_Camel
Sopwith_Camel
Ill check the oil again first thing tomarrow. sun rise 10:02.
but the air filters are off while I'm working on it.
bob67bgt
I may have missed a earlier post about this car but I would start at the distributor. Be sure the mechanical advance is not seized. Have timing set at 32 degrees before top dead center at 3000 rpm with vacuum disconnected and then mess with the carbs. If you think its lean then pull the choke out as you are about to hit 2500 rpm ( your bogging point ) and see what happens with a richer mixture. Good luck getting the little car running proper!
Sopwith_Camel
Sopwith_Camel
the vacuum advance has is ok, no the issue is with the carbs, I rebuilt them last year and just haven gotten them tuned up right.
it was running ok today but still not giving me power when I put my foot in it.
Im going to run out of warm weather soon.
steve
Gokart
Do you know of a garage locally that has a CO2 exhaust meter and (and a rolling road is handy). If you can find one and they can spend a little time fine tuning your car for not too much of a cost, that would give you a better idea of how close you were and what they did to bring things to optimum.
I did this. It took the garage 1/2 an hour and cost me $50. They said I was pretty close and it was only a bit of fine tuning to get it right. But having that sort of diagnostic equipement makes it a lot easier. They had the car running at 3000 rpm on the rolling road to get the optimum flow and were checking the timing at the same time.
I had followed the SU tuning instructions prior to the garage fine tuning. I used my ears and tube for the air flow rather than a flow meter.
If the carbs smell gassy that usually indicates the mixture is rich, which is a common MGB/SU tuning fault/problem.
I have to wonder with the exceptionally cold conditions if the weight of the oil in the pots may be too thick from being colder than optimum.:confused:
Gokart
Sorry, just noticed that the thread was from last year. New here and was looking back on some threads.
Did you get your car tuned properly?
Sopwith_Camel gassy carbs and other diet woes Spridgets 3
7 running lean and "gassy" exhaust smell? Triumph 4
RickB Gassy smell in cockpit - Solved! Thought I'd share Spridgets 4
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
jfarris For Sale SU H6 Carbs AUC 878 - SOLD Triumph Classifieds 0
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
steveg Healeys with Mikuni Carbs Austin Healey 13
P TR2/3/3A TR3B SU carbs Triumph 10
KVH General Tech Carbs Flooding While Car Sits Triumph 55
K 1966 Austin 1100 carbs? British Motor Corp 1
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
steveg HS vs HD series carbs Austin Healey 2
P For Sale v12 carbs Jaguar Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
steveg TR6 HD6 carbs on TR6? Triumph 16
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
Michael Oritt Leak from carbs Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
D Starting After Carbs Rebuilt Austin Healey 30
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
69MGC 65 to 67 carbs wanted MG Classifieds 4
K 66 Austin 1100 Carbs British Motor Corp 1
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
M Cooper's Air Filter on H1 Carbs Spridgets 5
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
sundown TR6 carbs Triumph 2
doc50 Su carbs for a Metropolitan? Other British Cars 1
S SU carbs AUD9124 on a Jaguar ? Jaguar 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D BJ8 Carbs Overflowing Austin Healey 20
T TR2/3/3A Will 5W/20 oil work ok in carbs Triumph 4
R TR2/3/3A Rebuilding H4 carbs Triumph 8
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
Jim_Gruber Screws for HS-2 carbs Spridgets 5
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 Topping up cd175 Carbs Triumph 8
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
HighAltitudeTR3 TR2/3/3A SU H6 Carbs all out of whack!! Triumph 14
J Backfire through carbs Austin Healey 3
