I don't use cork thermostat gaskets either, the thing i don't like about cork is it tneds to squish out place, a paper gasket won't do this, if the gasket set only comes with a cork gasket, i simply use it for template to cut one form gasket paper, the I use the same RTV (Permatex Ulimate Black)as i use most of the rest of the motor on it as well, also, I don't use studs on a thermostat housing, always bolts, the bolts won't snap years later when trying to remove like a stud will.
