Gasket brand
Michael Oritt
I bought an intake manifold gasket for my Elva/MGA 1600 of an ebay auction. It was pretty cheap: $5.00 plus $5.00 for shipping.
The gasket came in a "McCord Gaskets" box which is described as a subsidiary of J.P. Industries, Inc. The box is stamped "Contents Made in England" and the lettering says "Printed In USA".
Has anyone ever heard of McCord Gaskets before? The box looks like it has been sitting on someone's shelf for a while and it just seems unusual to buy a gasket made in England being sold in the US in packaging made in the US.
Whatever, it looks like the gasket will do the job....
Healeysince59
McCord is (was?) an old time US gasket company. I suspect that, when there was a market for them, they probably sourced brit gaskets from the UK and repackaged them under their brand.
Marv J
Jerry
I replaced my valve cover gasket the other day. I noticed that the gasket did not fit the valve cover very well. Are the 6 cylinder cars pretty much stuck with one manufacture for these gaskets now? I have bought the kits from many different suppliers and they are all Payen brand.
Jerry
BN4
BJ8
Payen used to be the one we requested, as it was known to fit, maybe it just shrunk from age/drying out?
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 9
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Failed intake manifold gasket? Triumph 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
RJS TR4/4A Fuel Pump Gasket Triumph 8
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
P MGB Zenith water choke gasket needed MG 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
DrEntropy MGB Head gasket R&R goes on... MG 13
tahoe healey Cork Gasket Prep Austin Healey 17
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
LAW75 Timing Chain Cover Gasket Austin Healey 12
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
B Bonnet hinge gasket Spridgets 10
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
R BJ8 Cylinder Head Gasket Austin Healey 38
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
B TR4/4A Head gasket won't lay flat Triumph 13
T TR6 TR6 Carb Gasket Sealing Triumph 1
Michael Oritt Manifold Gasket Dressing/Sealant Recommendations Austin Healey 6
K Gearbox Throw-out pin and gasket question Austin Healey 8
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
F Sump Gasket Question Austin Healey 15
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
F Heater valve/tap gasket- Install dry? Austin Healey 10
steveg Strange gasket pieces Austin Healey 5
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
Lin Oil sump gasket replacement Austin Healey 31
vette Valve Cover Gasket Austin Healey 18
