Fiberglass repair???
nomad
Figured you Lotus guys might have some insight into redoing old fiberglass car body's.
I'm working on 2 hardtops and a Berkeley if I can get to it this winter.
In my youth I made fiberglass motorcycle tanks and seats to fit flat track frames made by a friend of mine so I have some experience with new glass but not old. Wondering if there is any info or experienced folks on this forum that can give me info on old glass. The info on the internet that I have found covers boats mainly.
Specifically wondering if all cracks and crazes in the gel coat need to be v'ed out and filled. Boat info mkes it sound like they do and if so I have a big job ahead of me.
Kurt.
Grantura_MKI
There are many ways of doing this. I would first have the hardtops plastic media blasted. This wil;l show every defect. If you are going to dig out the cracks, then you will need to cut small pieces of Fibreglass matt out to fill the hole. I use 1.5 matt along with tooling resin. You may also sand down the whole surface down to the matt and re-apply resin/gel coat. You will need a special gun for this operation. Be sure to seal the new finish with a quality primer...nothing that contains MEK, etc in its make-up.
Hope this gives you a starting point.
N
nomad
Thanks much D.
I sold my pressure pot gel coat gun many years ago but may just sand away the worst of the crazing. I can get some 1.5 matt but gel coat and tooling resin are probably going to be a problem. Around here there are virtually no small fiberglass manufacturers left and the last time I tried to get something from a big company they would'nt even let me in the gate!
Your suggestions made me realize that I really need some tooling resin at the least and I will contact some supppliers to see if they can give me the name of a company that may be cooperative. I will probably be brushing on several coats and be skinning the whole piece with filler.
Thanks again,
Kurt.
Grantura_MKI
Not a problem. If you have any problems sorting out your needed supplies, drop me a note and I will help you from this end. Sounds like you know what is required to make this job happen! Be careful of using body filler, as it tends to shrink over time and the imperfections will soon be seen.
N
nomad
Thanks again. I'll keep your offer in mind but wish you were a little closer. I imagine shipping a gallon of resin would be a little expensive if you have it!
Kurt.
Grantura_MKI
I am in California at the monent. The resin is in the circa $40.00 per gallon range. Could probably place it in one of those flat rate boxes?
Westfield_XI
I have always had good results with products from Tap Plastics, they have an online catalogue and ship promptly. Home Depot boat resin is cheaper, but I have learned that the Tap stuff works better.
IMHO, the only way to get out gel cracks and keep them out, is to grind and fill. You could try a two part poly paint with a whole bunch of flex agent, paint over the cracks and hope for the best, if you are feeling lucky. If you do, let me know how it works out, the body shell of my eleven replica is spiderwebbed with cracks and I am looking for an easier way too........
N
nomad
Whoops---Sorry, I have'nt been back here for a while. Grantura I'll pm you if your still available.
Westfield, I plan on making up a little tool that will scrape out a v by pulling it along the crack. Thinking a heavy wire (#9) sharpened to a v and maybe case hardened. Maybe a little heavier if necessary.
Plan on using that on the long stray cracks and grinding away the spots where it looks like someone dropped something heavy on it.
Kurt.
Platinum
If it's an impact spawl, you will need to go at least an inch beyond the visible cracks. The 'spider-webbing' or craze cracking will be less problematic, usually just surface issues.
Lotuswins
Hello,
I haven't heard anyone mention an alternate method to grinding out the cracks, specifically the use of 'tissue' fiberglass cloth. Ray at RDent.com sells this very thin matte which seems to work quite well for the normal stress crack issue. I've done a few spots some time ago, which haven't resurfaced any cracks and it doesn't print through the paint like courser matte will. IIRC you sand down to the matte, then build up using this thin cloth. Sand flush and primer/paint. It has a stronger surface strength to prevent cracking like the gel coat will. I'm no expert, but it sounds great for areas where there is alot of crazing like around the hood/trunk/door corners and door handles.
Also, I assume when you refer to older fiberglass, its polyester resin, not epoxy resin we are talking about?
Jerry Rude
73 Europa
Westfield_XI
I assume that Lotus used the very cheapest resins in their bodies, I know Westfield do. Remember that when Chunky was saving pounds on his cars, it was pounds sterling that he was concerned about, not pounds avoirdupois!!!
N
nomad
Lotuswins said:
Hello,
I haven't heard anyone mention an alternate method to grinding out the cracks, specifically the use of 'tissue' fiberglass cloth. Ray at RDent.com sells this very thin matte which seems to work quite well for the normal stress crack issue. I've done a few spots some time ago, which haven't resurfaced any cracks and it doesn't print through the paint like courser matte will. IIRC you sand down to the matte, then build up using this thin cloth. Sand flush and primer/paint. It has a stronger surface strength to prevent cracking like the gel coat will. Jerry Rude
73 Europa
Jerry, I'm assuming you are talking a very fine light weave cloth not mat. If you are, it sounds like the chips!!
Ideal would be super fine cloth layer after bad gel is ground away.
Kurt.
Lotuswins
Kurt.
Kurt, you are exactly right, and sorry for using 'matte' and not 'cloth', as it is not a woven pattern material. And you do just grind the gel away, down to the existing matte or cloth and build up with the thin cloth to the surrounding surface level. It gives a surface that has some strength compared to pure resin on the surface like with gel coat. Only works on repairs I expect though? Anyways, it works great and if you don't want the crazing to return, this gives better assurance than just restoring the gel.
Jerry
N
nomad
Jerry can't find RDent and am going ahead with just a coat of resin over ground down crazing and opened cracks. No patience!
Kurt.
PAUL161
I knew a fellow who bought an old Corvette, 1954 and the body was so severely spider webbed that it was almost impossible to repair it where the spider webbing didn't come back. He was fortunate enough to find a supplier that made replica bodies out of modern fiberglass. That was the only way he solved the problem.
I would say that a good source for information on fiberglass techniques and suppliers is a boat manufacture. As you know, almost all boats today are fiberglass. JMHO. PJ
Westfield_XI
I have an old boat as well as a fiberglass bodied car and can tell you that in my case the gel coat issues are very different between the two. The boat, a 1983 Campbell , has gel coat cracks and crazing only due to impact damage. The fiberglass structure is so thick and stable that the gel coat never flexes under any condition and keeps the gel from cracking. The car body is more like the sort of fiberglass used on racing motorcycle fairings. It is very thin and has no bracing or structure, much like an eggshell. It is very light and rigid when it is attached to the car, but when it is open it is extremely flexible. This means that it develops stress cracks in the areas where it typically flexes as well as cracking at the edges where it contacts the chassis structure. On the boat the fiberglass is a minimum of 1/4" in the thinnest location while the car body is no thicker than 3/16" anywhere, plus the boat has plywood and solid spruce gussets, stringers and bulkheads. Of course, the boat has 550hp and struggles to top 70 and the car easily reaches 100 on 97hp. Horses for courses.....
KVH Fiberglass Repair and Hardner--Tranny Cover Triumph 7
G hart top fiberglass repair Austin Healey 1
I Fiberglass repair Triumph 3
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
R After market 3000 fiberglass hardtop Austin Healey 13
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
Editor_Reid Securing Bugeye Fiberglass Bonnet Spridgets 15
A TR4/4A Fiberglass Surrey Top question Triumph 3
BillyB62 TR2/3/3A TR3 Fiberglass hardtop Triumph 6
S TR2/3/3A green fiberglass fix it stuff Triumph 9
S TR2/3/3A fiberglass filler Triumph 4
RickB Any fiberglass one piece fronts available used or cheap? Spridgets 15
DanLewis New fiberglass Bugeye bonnet $395 [NFI] Spridgets 0
JamesWilson Fixing Fiberglass Flaws?? Restoration & Tools 9
O Bugeye Fiberglass Hardtop FS Spridgets 0
P Fiberglass hardtop Triumph 0
M open discussion on fiberglass tops Spridgets 18
RickB Box Spridget fiberglass front end - front mounting Spridgets 5
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
S help with identifying fiberglass frontend Spridgets 27
Stick Thoughts on Spridgetech Fiberglass Bonnets? Spridgets 2
M Fiberglass Bonnet SEBRING Spridgets 6
RickB Removing paste wax from fiberglass? Spridgets 5
RickB fiberglass question Spridgets 5
J Fiberglass Fenders for Early Midget MK1 Spridgets 11
A Wanted RHD dash, fiberglass bonnet Spridgets 6
Marvin Gruber TR6 TR6 Fiberglass fenders Triumph 3
KVH Fiberglass "Hardner"? Really? Triumph 7
D MGA MGA Fiberglass fenders MG 3
E 54 100-4 with fiberglass panels Austin Healey 13
Tr3aguy TR2/3/3A Shed some light on Fiberglass TR3 hardtop Triumph 9
B Fiberglass hard top installation Austin Healey 1
subnet_nd Fiberglass fenders Spridgets 2
Frankenhealey Fiberglass Hood Austin Healey 15
John Moore Fiberglass Frontend Spridgets 7
6 Fiberglass Lighter than Steel? Austin Healey 7
N Spitfire Spitfire hardtops metal or fiberglass Triumph 1
CraigLandrum TR2/3/3A TR3A Fiberglass cockpit capping woes Triumph 3
rlandrum TR2/3/3A TR3A Fiberglass Cappings Triumph 1
S Fiberglass Panels Spridgets 0
Jayrz FiberGlass Bugeye tail Spridgets 3
Ed_K To clean or not to clean off uncured fiberglass Austin Healey 12
6 Paint Detailing Question: Fiberglass Austin Healey 14
RickB How to? Attach fiberglass teardrop to metal hood? Spridgets 4
I Hard top fiberglass help Spridgets 19
T Fess up - who has used fiberglass fenders? Triumph 10
RickB What is this: '63 - 70 FiberGlass Front Sprite/MG' Spridgets 7
T MGB MGB Sebring fiberglass fenders MG 4
