Facet, Purolator fuel pump
aeronca65t
Re: Facet, Purolator fuel pump
I have the lower pressure Facet in my time trials Midget.....nice simple pump that has been reliable. It *is* noisey, though.
Dennis P
Have heard these are good, found them at NAPA for only $32.00. Does anyone know the proper one for MGB. Is it the 1.5 to 3.5 or the 2.5 to 4.5 lbs?Confused in NY.
wolfman
I have been thinking of installing one of these on my Midget, except for the noise. I was told if you mount it with rubber insulators the noise goes down considerably. Don't know if its true, but I will try it when my mechanical fails.
linmalki
You want the 1.5-3 # for a Midget, and either that or the 2.5+ for the MGB. I would probably start with the lower pressure pump, as these carbs don't like much pressure. If you find it starving--depending on how you drive--, try the next higher one.
G
You definitely want the lower pressure pump. The higher pressure one will push the needle valves open and flood the engine. You would need a pressure regulator to run the higher one. My SU pump runs right around 2lbs.
Bob
David_DuBois
Either on of the pumps will work fine. If 4 psi is pushing the needle vlave off the seat, there is something wrong in the carburetors. A new SU fuel pump can be either 2.7 psi or 3.8 psi, depending on the modle SU pump that is purchased. It is really a toss up as to which way to go. 1.5 psi would be very much on the low side for a pump mounted back by the tank, that is the pressure of the low pressure SU pumps that are mounted on the firewall of hte older (T series cars). Mounting a pump with only 1.5 psi in the rear of the car would be a bit on the wimpy side by the time the fuel got to the carburetors. The back up pump that I installed on our MGB is the 2.5 - 4 psi Facet pump and it work fine. If the Midget pump mounts in the engine compartment, then the 1.5 - 3 psi pump would be fine, otherwise, go witht he 2.5 - 4 psi pump. As for the reduction of noise when using the sound mounts, I can say from experience that the Facet pump mouned onteh sound mounts is quieter than the properly mounted SU fuel pump in a MGB.
Cheers,
DJThom
While I am using my original Lucas pump on my MGB, I've just bought a carter pump for my Elan. Link as follows:
https://www.racetep.com/webfuelspark.html#webfuel
This site raises some criticisms of the facet pump with respect to surging delivery, but it is focused on weber application. They also claim that a pressure regulator is not required. I'm no expert in this area and don't know if the criticisms are valid or even apply to SUs. Just an alternative to put forward for discussion...
Darren
Platinum
They're certainly adamant about the Facet units!
I have one on the MGB with a DCOE Weber and haven't had a problem in 50K+ miles... My Elan has an SU "tick-tock" in the trunk, mounted on rubber bobbins. It too has given good service.
tony barnhill
Great Pumpkin - R.I.P
Why not rebuild the SU pump? you can do that for about the cost of a new aftermarket pump?
I'm kind of an original equipment buff (on some things), and the SU fuel pump is what I would use (and do use).
Bayless How do you mount a Facet fuel pump? Spridgets 10
steveg Facet pump - explanation for superiority over SU Austin Healey 13
bugedd Facet pump died Spridgets 18
TulsaFred Airtex vs Facet fuel pump Spridgets 29
G Facet pumps any good? Spridgets 23
drooartz MGB-GT Facet fuel pump location MG 11
drooartz MGB-GT Facet vs SU fuel pumps MG 18
AH67 facet fuel pump never stops ticking. Austin Healey 6
Lin Facet Fuel Pump Spridgets 18
R Facet fuel pump MG 4
R GT6 Facet Fuel Pump Alternative [GT6] Triumph 4
dklawson Metal vs Plastic Facet Pumps ? Spridgets 2
T Normal for a Carter/Facet pump to be hot Triumph 11
Sebring222 Facet Fuel Pump Other British Cars 9
sparkydave Facet fuel pumps reliable? Spridgets 23
athenssprite Facet fuel pump - for use on 1960 BE Spridgets 16
healeynut Fuel Pump - Bendix/Facet Austin Healey 0
healeynut FACET Square Body Pump Woes Austin Healey 4
C Facet fuel pump Austin Healey 6
roofman Facet electric fuel pump - need advice Triumph 15
Sarastro Facet fuel pump question Spridgets 5
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
af3683 TR2/3/3A Original Purolator Oil Filter Canister Triumph 6
TR3MT TR2/3/3A Purolator Oil Filter Leak Triumph 10
T TR2/3/3A Is it a Purolator or Tecalemit? Triumph 5
H Purolator oil pressure relief spring Triumph 1
K Oil pressure or balance valve on top of Purolator Triumph 1
SkinnedKnuckles Purolator Fuel Filter Alert, I guess. Triumph 5
BritCarFan STP versus Purolator oil filters Jaguar 10
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
