TR2/3/3A Extra wire in the harness
DavidApp
My TR3A kit came with a new wiring harness. Probable from British Wiring manufactured in the late 1990.
I have been installing it as I go and have found what appears to be an extra wire. The Green/Brown from the flasher unit ends up on the passenger side where the horn and head light connections are made. Then there are 2 Green/Brown wires going from that point to the same point on the driver side.
I will connect the flasher wire to one of the wires that go to the other side where it will be connected to the wires that go up to the indicator switch. That will leave one wire unused.
David
TR3driver
Great Pumpkin - R.I.P
Are you sure one of them isn't GR instead of GN?
The harnesses are ambidextrous, which means there is a wire that winds up not being used. But I think it should be a GR wire on LHD cars.
DavidApp
Thank you.
Good call.
There is a slight difference in the stripe but it is faded red. Did occur to me that it could be LHD and RHD harness.
I am using the diagram put out by Auto-Wire.
Green/White goes to the RH lights which I am taking to be the passenger side.
David
James Christie
I think you will find that the harness is destined to be used on lhd and rhd cars, thus there will be several redundant wires which are destined to the indicators and horn controls
james
DavidApp
Hello James
The harness is 20 years + old so the difference between the brown trace and the red was difficult to see but when the suggestion was made I did a double check and that is the case. One green/Red and one green/brown.
Not being an electrician I am being super careful with this part of the build.
David
G
Ggrant162
This exact thing happened to me with a new harness (from British Wiring). It is made for left and right hand cars. Drove me nuts, thinking there was a break in my brand new harness! You have to add a bridge connector at the RH fender to send the connection back to the LH wire which connects to the LH signal light.
TR3driver
Exactly as original.
NardisCNC An Extra Wire... Please Help!! Spridgets 8
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
R Extra 948 and 1098 Engines Spridgets 9
D TR2/3/3A extra hole in my water pump? Triumph 3
S TR2/3/3A Tr7 and a little extra Triumph 2
PC in the movies, an MG-TF [with extra cheese] Spotted 3
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
D extra stop/brake light Austin Healey 33
D TR4/4A extra long oil filter attachment stud Triumph 9
T TR4/4A Extra carpet pieces? Triumph 9
Rob Glasgow Extra clip - Austin Healey 5
J ??Purpose of extra holes in wooden seat runner spacers?? Austin Healey 4
tinman58 TR5/TR250 Extra gaskets Triumph 3
M TR2/3/3A Extra holes in bulhead Triumph 7
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
P TR6 Extra digit in title Triumph 8
DNK Got an extra 100 Large? Lotus 3
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
JPSmit MGB, LBC graveyard & an extra Spotted 10
Banjo TR4/4A AAAAUG! anybody got an extra TR4A piston? Triumph 3
V How much extra engine oil with oil cooler??? Spridgets 5
Number_6 If I had the extra money... Triumph 11
S MGB MGB engine mounts - "extra" plate? MG 2
angelfj1 Anyone have an extra one of these? Triumph 10
G anyone have an extra front side marker lens? Spridgets 8
KVH TR4/4A TR4 Water Pump Extra Vane Triumph 7
tahoe healey extra fuse box Austin Healey 1
R ADDITIONAL FUSING FOR EXTRA PRECAUTION? Austin Healey 15
S Doc, ya gotta be EXTRA good this X-mas!! Other Cars 11
jlaird Came into a few extra dollars Spridgets 5
E GT6 Do i need to fabricate extra supports for the GT6? Triumph 9
N Maybe a little extra! Triumph 2
CCURTISS T-Series Extra MGTD/TF Clutch Actuating Fork???? MG 2
regularman Extra cooling idea Spridgets 33
mgb4tim "MG" Key Blanks - I'll have a few extra. MG 4
mgb4tim Wedge TR7 Key Blanks - I'll have a few extra. Triumph 0
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
tony barnhill T-Series Extra MG TD Parts MG 26
tony barnhill T-Series Extra TD Stuff MG 16
jlaird Extra! Extra! Extra!! Spridgets 0
tahoe healey Extra rear light. Austin Healey 8
jlaird If you have an extra 25 min Spridgets 0
DNK SOMEBODY HAVE EXTRA TIME IN THE MIDWEST??? Triumph 4
regularman A place for extra fuse holders. Spridgets 5
P extra brake lights Triumph 10
Gray_Cat The 2 1/2" Of Extra Leg room in A Bugeye. Spridgets 2
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
T Extra Wires? Triumph 11
G Lotus super seven 1964 Extra car to buy Lotus 1
jlaird Todays extra credit question is... Spridgets 1
