Extra rear light.
I just finished the conversion of the rear reflector to a turn/stop light. It was easy. I had read that the cutting of the rubber seals was to be a problem. I put them in the freezer for a couple of days and the drill went right through. This is a great improvement to visability from the rear and looks stock/original. Very exciting!
TH
Dave Russell
Yoda - R.I.P
Good move. It sure does increase visibility.
bighly
Rich which lights did you use? What was the cost?
tahoe healey
Tracy, I used the 20 watt, BA15D Bayonet bulbs and bayonet socket from Pureland Supply. (www.PurelandSupply.com) Part numbers C-88 and GBD. I used the narrow beam as I read the reflector disperses the light well. With shipping and parts the bill was $48.40. I bought new reflectors on E-bay (a bit cheaper than Moss) and replaced the new lens with the Lucas originals. It has nice new chrome and rubber. Fits well and looks perfect. This was as written-up in Healey Marque in May of this year by Charlie Baldwin. Thanks, Charlie!
TH
Johnny
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif BRAVO to all who do this modificatioin. It really enhances the safety of our cars.
Dave Russell
Yoda - R.I.P
This same modification can be done on the older BN1 - BN2's. Since the reflector pods are a separate part & the aluminum pods are closed on the surface under the reflector, an extra step of cutting a hole in this closed surface with a hole saw is required. Also a hole with grommet through the shroud for the wire.
The later model rubber housing, socket, & trim ring can then be fitted. A little work to cut the rubber to fit & hold the bulb, but it comes out looking the same as original. A high speed grinder (Dremel) works well to shape the rubber.
I used the MR11 10 watt, 30 degree bulbs with matching ceramic pigtail sockets. See attached pic.
Keoke
Whats the Penney for Dave, the fuse?---Keoke- /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Keoke
Nope I didn't have the specks on the first time Dave, so I took another look. Still look like a penny to me.---Keoke- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
R Extra 948 and 1098 Engines Spridgets 9
D TR2/3/3A extra hole in my water pump? Triumph 3
S TR2/3/3A Tr7 and a little extra Triumph 2
D TR2/3/3A Extra wire in the harness Triumph 7
PC in the movies, an MG-TF [with extra cheese] Spotted 3
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
D extra stop/brake light Austin Healey 33
D TR4/4A extra long oil filter attachment stud Triumph 9
T TR4/4A Extra carpet pieces? Triumph 9
Rob Glasgow Extra clip - Austin Healey 5
J ??Purpose of extra holes in wooden seat runner spacers?? Austin Healey 4
tinman58 TR5/TR250 Extra gaskets Triumph 3
M TR2/3/3A Extra holes in bulhead Triumph 7
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
P TR6 Extra digit in title Triumph 8
DNK Got an extra 100 Large? Lotus 3
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
JPSmit MGB, LBC graveyard & an extra Spotted 10
Banjo TR4/4A AAAAUG! anybody got an extra TR4A piston? Triumph 3
V How much extra engine oil with oil cooler??? Spridgets 5
Number_6 If I had the extra money... Triumph 11
S MGB MGB engine mounts - "extra" plate? MG 2
angelfj1 Anyone have an extra one of these? Triumph 10
G anyone have an extra front side marker lens? Spridgets 8
KVH TR4/4A TR4 Water Pump Extra Vane Triumph 7
tahoe healey extra fuse box Austin Healey 1
R ADDITIONAL FUSING FOR EXTRA PRECAUTION? Austin Healey 15
NardisCNC An Extra Wire... Please Help!! Spridgets 8
S Doc, ya gotta be EXTRA good this X-mas!! Other Cars 11
jlaird Came into a few extra dollars Spridgets 5
E GT6 Do i need to fabricate extra supports for the GT6? Triumph 9
N Maybe a little extra! Triumph 2
CCURTISS T-Series Extra MGTD/TF Clutch Actuating Fork???? MG 2
regularman Extra cooling idea Spridgets 33
mgb4tim "MG" Key Blanks - I'll have a few extra. MG 4
mgb4tim Wedge TR7 Key Blanks - I'll have a few extra. Triumph 0
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
tony barnhill T-Series Extra MG TD Parts MG 26
tony barnhill T-Series Extra TD Stuff MG 16
jlaird Extra! Extra! Extra!! Spridgets 0
jlaird If you have an extra 25 min Spridgets 0
DNK SOMEBODY HAVE EXTRA TIME IN THE MIDWEST??? Triumph 4
regularman A place for extra fuse holders. Spridgets 5
P extra brake lights Triumph 10
Gray_Cat The 2 1/2" Of Extra Leg room in A Bugeye. Spridgets 2
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
T Extra Wires? Triumph 11
G Lotus super seven 1964 Extra car to buy Lotus 1
jlaird Todays extra credit question is... Spridgets 1
