TR6 European specks on a 1970 TR6 engine
Got_All_4
Picking up a parts car on saturday for my 69 TR6 project. Found a 1970 TR6 but came from Europe. Not to many salvageable body parts but has A type overdrive. Was hoping for PI but lucked out there. Anyway my question is is there any way to determine if this is a Euro speck engine. Hotter cam, higher rocker ratio and higher compression?
Thinking if I can use the cam and higher compression head and rockers to get a cheap upgrade in engine performance. Oh ya speedo is in kilometers.
TR3driver
Great Pumpkin - R.I.P
IIRC, the early PI engines had a CP prefix on the serial number, instead of CC for carb models.
Rockers are the same. But if the PI has been replaced with carbs, I wonder if they might have swapped head & cam too?
Tybalt
As Randall said, look at the engine number. If it is from the "CC" series then it is an early carb engine while a "CP" would be an early PI engine. Also take a look at the valve springs as quick and dirty but not entirely accurate indicator. The "CC" engines used a single spring while most of the "CP" engines used dual springs. Some of the late "CP" series used a different rate single spring than the "CC" engines but as near as I can tell those were limited to some of the 1972 model year cars. The other variable on that is that someone may have fitted their "CC" engine with dual springs. I have dual springs on a "CC" engine that have the spring rates and subsequent seat pressure matched to the camshaft I am using.
Got_All_4
Got_All_4
The guy I bought it from purchased it from the original owner who drove it in Europe and when he moved back to the US he had it shipped here. Unfortunately the paper work was tremendous and never did anything with it but put it in a dirt floor barn for decades. This guy did all the foot work and got a title then discovered it was too far go for him to redo. That's where I come in.
I'll start busting it apart Saturday and let you know what I find. My 69 motor seems fine and it does turn however I couldn't get it to start. No spark and discovered that there was an electric fuel pump mounted under the car. No way to know why it was installed and would have been prier to 1982. Maybe the cam lob is worn. My 69 has 50+k on it while the 70 only 25k. I'll check internals for wear and use whatever is best however I still want to use the original engine. If I'm not mistaken the cranks are different in a 69 and 70?
I need wheels for mime and someone recently sandblasted the wheels, painted them and put new tires on them. Not redlines but that's a good savings for me. My 69 has a couple of wheels that have the studs for the Rostyle hub caps and for the price of those I not getting into.
TR4nut
I think only the Tr250 and 69 TR6 had the different cranks. My 70 is the same as the later engines.
Got_All_4
Got_All_4
That's what I meant about the cranks Randy. Car is here safely. What a rats nest! Sucked more foam, raise-nets, skeletons and a few good surprises too. Like a box of Cracker Jacks. I'm not believing this story about a Euro car. Speedo looks like MPH not kilometers . Engine # is CC and single valve springs. Although there is a E at the end of the engine number. Don't know what that means. Had to throw away the air cleaner housing. Full of mice junk and rotted away from holding the moisture. Carbs were full too.
Whats amazing is someone started on this car as a project. Did the wheels, put clean anti freeze in the engine. There is no driver side or trunk floor. Every fender has rot through some wear. The battery box is rotted through the fire wall along with other places. I guess anything can be fix but what were they thinking.
Got the carbs off, radiator and front bumper came off in a snap. How do you get the rear bumper off? Every bolt just spins and there doesn't seem to be a nut behind the brackets. Don't know how you would even get a wrench in there if there was.
Anyway here is some pics.
stretchit2 4th European Healey Meet Austin Healey 4
D Dallas - All British & European Car Day - 5/5 Spridgets 3
Cottontop All European Car Day [formerly All British Car Day Austin Healey 0
L A quick question for you UK/European LBCers Spridgets 0
B MGA European Car Magazine April '93 [MGA to 1800 info] MG 2
tony barnhill European Trip Spridgets 24
tony barnhill European Trip MG 12
P British / European Bike Day at Washington Crossing British Motorbikes 0
Sherlock British/European Car Show pictures [Calgary] Other British Cars 7
aeronca65t European Junkyards Other Cars 2
Sherlock Pictures from Calgary European & British Car Show Other British Cars 5
P European Spridget Racing Spridgets 2
T Wedge TR7/8 European Bumpers? Triumph 3
mctriumph TR2/3/3A Back to 1970 Triumph 1
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
T For Sale 1970 TR6 project car Triumph Classifieds 0
Dontyler MGB-GT Sorting my new 1970 MGB GT MG 12
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
P TR6 1970 TR6 Timing Question Triumph 2
H Wanted 1970 MGB rear bumper irons MG Classifieds 0
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
AngliaGT For Sale 1970 mgb gt MG Classifieds 4
GTP1960 Nice driver VW Transporter T2. 1970? Other Cars 0
bcliff For Sale 1970 MGB Roadster and other British cars for sale MG Classifieds 0
AngliaGT 1970 Volvo 142 Other Cars 8
TomMull US car assembly standards in the 1970's Other Cars 13
sd80mac7204 Spitfire 1970 Brake question Triumph 3
sim 1970 H2 carb question Spridgets 2
S 1970 Mercedes 280 SL Other Cars 4
Simmo MGB 1970 MGB Speedometer Faceplate MG 5
smaceng TR6 Information Needed on 1970 TR6 Commission Number / Plate Triumph 6
F TR6 Just about finished- 1970 TR6 Triumph 17
JodyFKerr MGB 1970 MGB restoration MG 1
JodyFKerr MGB Tanith's 1970 MGB MG 15
Sherlock 1970/73 Vauxhall Firenza [Canadian version] Spotted 6
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
rovernut 1970 series 2 e type serial number location Jaguar 6
S XKE 1970 Series II OTS Outside Mirror Jaguar 3
RickB MGB-GT 1970 MGB GT restored by Chris Longo - 1st in show! MG 10
B 1970 XKE 4.2 rear main seal Jaguar 2
M Spitfire 1970 Spitfire Dash Triumph 11
S 1970 MG Midget Gearbox Spridgets 2
1 GT6 1970 gt6 floors first look- not as bad I thought! Triumph 16
S 1970 MG Midget MG 5
V Locking gas cap for 1970+ Midget??? Spridgets 14
