Engine transplant
99NCXJ
I've lined up a purchase of (4) TR4's and one of them is complete enough to restore. The other 3 are basically parts cars. My question is, What "modern" engine is a popular swap for these cars?
i know... someone is going to bash me for not rebuilding one of the several original engines but I have a vision of how I want this car to be and the original engine doesn't fit my plans. Plus, those people who decide to tell me that I'm breaking some kind of "triumph code" by ditching the stocker just won't have first dibs at the tons of parts I'll have up for sale :laugh:
So, Other than some crazy V8, what is a good engine/tranny combo option?
Geo Hahn
Well, Triumph put a fuel-injected straight six in there and called it a TR5.
I have certainly seen V8s -- some beautifully executed, some hack jobs.
glemon
I agree about the v-6 idea if you are not looking to go with a monster v-8. Old small to mid size trucks are often good doners, they have RWD motor tranny set ups instead of a transverse transaxcle like most front wheel drive, and many had 5 manual trannys. There is a lot of room for an engine in the TR engine bay, I have seen plenty of small block Ford and Chevy swaps, the smaller lighter Buick/Rover V-8 is a great option for most smaller LBCs, probably wighs less than the original 4 cylinder lump.
TR4A_IRS
3798j said:
Geo Hahn said:
Well, Triumph put a fuel-injected straight six in there and called it a TR5.....
Or if you have deep pockets, I'd go this route - "M" power. https://bringatrailer.com/2011/08/21/ultimate-motoring-machine-bmw-powered-1973-triumph-tr6/
I like this idea too! (full disclosure, my DD is a BMW...)
I have often thought that the non-M, M50 engine would be a good choice as well. 200 hp, vs. 240, but you could buy an entire 94-98 325i for under $4000, and have all the parts, including the driveline and electronics, you would need for a conversion.
DanB
Go to Britishv8.org and click on photo gallery, then Triumph cars. You will see many successful conversions. Also on the forums section of that site is a very nice, high end conversion being done on a TR4A in the Netherlands I think. Be sure to look at Calvin Grannis's TR6, both in the gallery and the sticky on the Triumph forum. Ted Lathrop's TR6 is also a must see, and Dale Knapke's 2.3 turbo ford conversion. If you are near Durham you need to check out Flying Circus. Where is Belmont?
Dan B
DanB
Max is the guy you need to talk to at Flying Circus. There are several conversions, mostly MGB, that are near you.
George Zeck 1098 v. 1275 engine transplant ?? Spridgets 13
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
