TR2/3/3A Engine Harness and/or Attachment Points for TR3
PatGalvin
Hello All
I have an engine cherry picker and the hoist gizmo that allows you to adjust the angle of engine (or engine/tranny) to slip it into the engine compartment. My question is: How have forum members connected to the engine? Has anyone fashioned special brackets for this purpose or is it just too simple to attach chains to various bolts around the engine?
There's so much innovation from this group, I thought there might be some good ideas on this.
Thanks
Pat
DNK
The 6 has lifting brackets built on to it. Well, actually bolted to it.
Twosheds
The TR3A has lifting brackets built on to it. Well, actually bolted to it.
TR3driver
Great Pumpkin - R.I.P
I believe the factory only left those brackets on the later engines. Earlier cars did not have them.
You could certainly add them, but I believe some of the studs actually got longer to accomodate the brackets. Personally, I just use chains.
PatGalvin
PatGalvin
Does anyone have a photo of these lifting brackets? or can describe where they are located? I thought I was pretty intimate with my engine (OK, stop laughing) and don't know where these are located, if I've even got them.
Pat
Twosheds
PatGalvin
PatGalvin
Thanks John
I don't have either of these fitted to my 59 TR3, Comm No. TS35XXX. Good to know about those. If anyone has photos of those mounted on their car, I'd be interested in seeing them.
Pat
Geo Hahn
Lookee lookee:
PS -- photos are from a TR4 w/o a heater (hence the street ell with plug and the blue harness) but I believe the mounting of these was the same for the TR3A.
PPS -- note the thickness of the rear bracket and the amount of threads exposed on the RR stud -- as Randall noted, this stud is longer on cars fitted with the rear bracket.
PatGalvin
PatGalvin
Thanks George
This is very helpful. And yup, I've never seen these before. but could now probably fab up something similar for use.
Much appreciated
Pat
MisterB How to spin engine sans wiring harness? Austin Healey 3
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
andrea AH 100/6 Longbrige 1957 engine comp,Wiring Harness Austin Healey 9
B engine harness MG 12
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
