Engine dissassembly/reassembly
beebopbogo
Member
As a kid, I've always loved taking radios and stuff apart and putting them back together to see how they work. If something electronic broke, I'd get permission from the 'rents to dissassemble it, after which I'd put it back together and it would quite often work afterwards (dust or connection problems, I'm assuming).
Anyway, I'm vaguely thinking about taking my MGB engine apart, cleaning it, and putting it back together again. I have tons of time, but very little money. I already have a basic tool set, but nothing to lift the engine. Is there some cheap way to lift the engine out of the compartment?
I've seen those tilt/lift things in the Moss Catalog... What are your suggestions on building some kind of wooden contraption from which I could hang the engine off of?
Adam
Steve_S
I've seen someone pull an engine with a $30 come-along hanging from his garage roof. He moved the car backward as he lifted the engine.
Bugeye58
Check with your local rental place. They should have an engine lift, (cherry picker) available for a decent rate. Rent it for a day to remove the engine, and then rent it again to reinstall.
If you are going to tear the engine down, you may want to look into purchasing an inexpensive engine stand. I have one from Harbor Freight that I paid 39 bucks for that has served well.
Before you get into this, make sure you have the appropriate manual to reference.
Jeff
beebopbogo
beebopbogo
Member
Cool. Thanks for the input. Sounds like it's perfectly doable. I'll make it next summer's project /ubbthreads/images/graemlins/smile.gif
Salyers890
set of measuring calipers and feeler gauges is a necessity from what i hear - never did it though. . . . . also murrays and pep boys have a tool loaner program which lets you essentially borrow specialty (EXPENSIVE) tools at no cost to you (just a deposit you get back) some things you will be able to borrow are a piston ring compressor, valve spring compressor etc. now, being limited on your moneys could put you out if you do this, due to the whole 'might as well' syndrome. example (might as well get new piston rings, might as well get new main bearings, etc.) if you can deal with that, all the best to you buddy - and i'm sure you'll have a blast.
have fun,
Mike
V8Blazer
Member
Thats the truth though. If you figure it will cost you X amount of money to complete a project (cars particularly), multiply it by 3 and that is what it will cost. The nickel and dime, Mickey Mouse purchases add up.
Salyers890
not to mention if you open it up and find something wrong, you wouldn't want to put that part back in would you? just to take it out again to replace it? then your B is off the road for a while while you're gettin parts. . .. . again, i'm not trying to discourage you - just offering insights - a friend pulled is drivetrain on his midget to find half of one of his synchro gears(literally in half) laying on the bottom of the trans housing. his project? cleaning and painting engine bay and engine. projected cost = 20-30 bucks in paint and a bunch of time. estimated actual costs (haven't dropped oilpan on engine yet) = 150 for trans overhaul kit, then the paint, new Ujoints on the driveshaft, don't forget gear oil and motor oil, and at least a few gaskets. Disassembling the motor would be a GREAT learning process, but I would rather wait til prepared to do a rebuild.
One option would be to junkyard/ebay/classified for an engine like yours and take that one apart and put it together at your leisure without losing your driveable car in the meantime - then after you're done - you have an engine spare!!!! this might not be the best option - but certainly a decent alternative.
cool question and i could definitely see myself doing it though
Mike
MGTF1250Dave TR4/4A TR 2-4A Engine Dissassembly Question Triumph 5
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
