Engine basics - help please
ichthos
Kevin,
I have white/grey smoke coming out an engine after it heats up for about five minutes. If I take engine cylinder pressures, and I then add oil to each cylinder again and pretty much get the same readings, wouldn't this point to something being wrong with the head? Any thoughts?
Kevin
Brosky
First of all, that is just about hot enough to get condensation turned into smoke in cold weather created out of the water that forms in the muffler as the hot car cools down, so let's talk about how it is after 10-15 minutes or better yet, 10-15 miles.
Are you losing any coolant on a regular or daily basis?
What were the readings that you got when you checked the compression dry and then wet?
Did you have the throttles wide open when you did the compression test?
hondo402000
is it smoke or Steam like Paul says. smoke will keep wofting in the air, if its condensation inside the exhaust system that gets turned into steam it will disappear a few feet from the car and once the exhaust system heats up it should be gone altogether. IF after a 5-10 minute driving and you still have white smoke thats another issue
Hondo
TomMull
All above seem like good advice. A little oil (common in most cars of this vintage)in the cylinders will exacerbate the smoke from a slight combustion leak but however slight, all combustion leaks are bad.
You can get a combustion leak test kit from NAPA (or others) for about the same price as you'd pay a shop for the test.
Tom
DNK
Kevin you just did your head. Is this from just starting it or have you been using it a while??
I
ichthos
Don, this is not the TR6. I ended up rebuilding the entire engine on it. Thanks for all the suggestions. I sounds like I have more testing to do, but it will have to wait for the weekend. I may just pull the head anyway - all I will waste at best is my time and a head gasket. Thanks everyone,
Kevin
I TR6 69 TR6 engine rebuilding basics advice Triumph 14
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
