BJ8s used the smaller outer bearing, to allow for thicker cross-section of the front splines.
If you have spindles that have the caliper bracket built in, you need the smaller bearing and the later (thicker) splined hubs.
If your spindles have separate caliper brackets, you'll need the larger outer bearing and the earlier 3000 MKI-MKII splined hubs.
Theoretically, you could put the earlier hub on a later spindle, as long as you machined a ring-adapter to fit the smaller bearing in the bigger hub. Not sure how one would go about fitting the larger bearing in the smaller hub...
