door window glass
JMACK
Hi, rather new to the forum but I have posted some Q & A's. I'm putting a "76B back together, I didn't take it apart, hence my problems. So far I have reinstalled: engine,transmission,pedal box,clutch slave, winshield and frame, radiator,headlights,taillights,body trim,door handles, brake lines etc,etc,etc. All has gone rather well, but I feel I spent way to much time installing the driver's side window and vent frame today, any correct steps, procedures would be great, as I still have the passenger side to do.
Thanks, John Mack
adam90009
make sure that you have the window winderuper meatl part in the door first and slide the glass in from the top of the door on its side and the a little of menuvering later get everything where it need to be and bolt it up. maybe someone can explain it better.
chris roop
Vent frame first. Snug the down nuts almost first, then do the horizontal bolts through the front of the door definitely snug. Now go back and do the snug on the vertical nuts. Secure the bottom of the frame (look for the marks in the paint for positioning).
Follow the advice above for placing the window winder; stick the mechanism through the winder hole, then get the tracking wheels in the channel, and bolt up. Again, it helps to look for past evidence of where the washers were before when snugging up. If it is tight, adjust the rear felt channel.
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
nichola TR6 Door handle and window crank installation Triumph 0
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
JFS Wedge Door wing window finisher Triumph 2
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
Trevor Jessie replacing window rubber and felt in door Spridgets 6
Jeepster Door to window brush seal Austin Healey 0
C TR6 Door window adjustment Triumph 2
2wrench TR6 Help installing door handles/window regulator handles. Triumph 9
6 Door Window Seals Spridgets 6
F Need help finding a part- door window track piece Austin Healey 5
K TR4/4A TR4A window/door crank handle removal? Triumph 11
B Installing window winders and interior door handle Austin Healey 4
T TR5/TR250 TR250 Fuzzy Door & Window to Windscreen Seals Triumph 3
G TR6 TR6 innner door release and window crank removal Triumph 5
L Door handle and window crank escutcheons Triumph 7
M Door window drip seals Spridgets 2
S Door Window Scrubbers Austin Healey 7
memphis Door Window Weather Strip Austin Healey 3
memphis remove door handle and window crank Austin Healey 18
M New Door Window Seals Question MG 1
HAN8L1965 DOOR WINDOW INSTALATION 65 Spridgets 5
T Door side vent window Mlll Midget Restoration & Tools 4
J BJ7 - Removing Door and Window Cranks Austin Healey 21
N TR6 TR6 Passenger door and window fit ? Triumph 5
regularman Door window seals Spridgets 1
B sed The window edging that attaches to the door... Spridgets 5
B TR6 TR6 door window alignment question Triumph 7
I TR6 TR6 window door pull/window seal help Triumph 6
Brosky Easy door/window handle R&R Triumph 3
Paulus Door to window seal installation? Triumph 7
Jack_Long Door Window Reinstallation MG 5
D Door Lock Tumbler Austin Healey 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
