Disassemble quarter eliptical leaf springs
BillyBud
My leaf springs look OK, not bent in the wrong direction or horribly rusty. However there is a lot of road crud built up in mostly the top small springs. I can probably get that out with solvent (for road asphalt) and a thin slice of metal, but was also wondering if anyone has disassembled these springs. There is a weird looking bolt through the end which I suspect is pressed in somehow on one end and bolted on the other. If this could be removed it would make cleaning a lot easier. Can it?
Really not interested in buying new 10 leaf springs, mine are usable.
RickF
They can be disassembled, cleaned up, painted, and reassembled. The stud in your photo is used to line everything up and is actually just a bolt with a round head. The biggest concern is the hardware fastening the leaves together. The small clamps are usually rusted solid and you may have to find new screws, tubes, and nuts that hold the clamps together. The small U-bolts at the eye end of the spring are hard to find. Do your best not to break them. I coated the leaves in this set with a graphite impregnated paint before reassembly.
Jim_Gruber
Bugeye Guy has the small U bollts which formerly were unobtanium. The Larger U Bolts will unscrew and you can get apart. Soaking for several days in PB Blaster or bathing in Washing Soda - Google Electrolytic Rust Removal will aid in getting these apart. A Battery Charger, a Sacrificial Anode, and some Arm and Hammer Washing soda, and a tub big enough to immerse the spring set, Some cheap Battery Cable Clips or really cheap Battery Cables and that is all you need. 24 Hours later those screws will come apart. That bolt that holds the leaves together I sim,ply used a BFH and a smaller bolt to pound things apart. I painted wit hsome black actually more like dark grey graphite paint Source Tractor Supply, And just put everything back together. Done this twice now and as long as you are careful taking apart it's petty simple to do. No Squeaks afterwards.
Oh and those round tubes, you can find some that will work at Ace Hardware. I think i needed to use two as I could not find long enough but it worked.
B
BillyBud
Great info, thank you! I also need a couple of those top spring plates as one is rusted away and the other is just missing. The bolt block seems ok, it's just the extended plate which looks suspiciously like a bench planer blade, which I may try since I am told these are on backorder forever.
B
BillyBud
One more question: the bolt gizmo on one spring had a very rusted off vestigal little leaf, but the other side had none, and no sign of one ever being welded to it. I was going to make two new little leafs and weld them on but thought I'd ask first if this was the way the originals were.
bugedd Disassemble top bow Spridgets 1
Bob_Spidell Disassemble Speedo Adapter Austin Healey 2
C Front Calipers - Disassemble or not? Austin Healey 15
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
chicken BJ7 Rear Quarter Panels Austin Healey 6
J Tips for quarter elliiptic spring install Spridgets 3
M Quarter light rubber replacement Austin Healey 6
R Quarter light glass removal Austin Healey 6
Joe Schlosser Quarter Eliptic spring bushing Spridgets 6
T For BJ7/8 Safety: add a quarter light mirror [or two] Austin Healey 6
maxwedge5281 BN6 rear quarter panels installation Austin Healey 4
K TR2/3/3A Cockpit quarter rails? Triumph 11
R Rear quarter elliptical suspension changing Spridgets 12
bugedd Quarter Elliptical Springs Spridgets 6
B BJ7 & BJ8 Interior Rear Quarter Panels Austin Healey 12
CessnaTPA Rear Quarter Panels Austin Healey 14
PatGalvin TR2/3/3A PS Quarter Panel Repair - need a patch panel? Triumph 6
R Removing rear quarter elliptical Spridgets 5
drooartz Bugeye quarter panel structure Spridgets 5
B BJ7 Rear quarter panels Austin Healey 0
PatGalvin TR2/3/3A TR3 PS Quarter Panel Dog Leg needs a good home Triumph 2
Mickey Richaud T-Series GT Rear Quarter Window Catches MG 4
T Quarter light removal Austin Healey 5
chicken Quarter light position to high Austin Healey 2
T BE Quarter Elliptic Mounting Bolts - threads gone Spridgets 5
P GT6 GT6 Repairing Rust in Rear Quarter Triumph 8
HAN8L1965 Windshield Quarter light alignment? Spridgets 1
T Question regards Quarter Elliptic Rear Springs Spridgets 6
chicken How do the rear trim quarter panels fit Austin Healey 25
germanmichel How I can dismount the rear quarter panels ....? Austin Healey 4
davidk Quarter Master Throw out Bearing Triumph 8
v8mgbal quarter light mirror Spridgets 2
Stewart Windshield alignment quarter light issue MG 9
H door and rear quarter panels BN 7 Austin Healey 1
G TR2/3/3A QUARTER PANEL, L/H [dogleg] for TR3 Triumph 1
B Need BJ-7 Rear Interior Quarter Panels Austin Healey 2
G Quarter Light Frames Cracked! MG 0
G Quarter Light Frames MG 3
G Looking for Quarter Light assembly MG 4
AUSMHLY Attaching the quarter panel Austin Healey 6
AUSMHLY Attaching the quarter panels Austin Healey 8
RobSelina Rear quarter pannel replacement/conversion Spridgets 4
AUSMHLY Attaching the quarter panels Austin Healey 1
M bugeye quarter panel question Austin Healey 0
M bugeye quarter panel question Spridgets 2
B 1/2 Eliptical Springs Compatability Spridgets 3
GB1 1/4 Eliptical Rear Brakes Spridgets 6
