Dead pedal and pedal positioning project paper
HealeyPassion
Guys,
In my search to find a more comfortable place to put my left foot for long drives, and better positioning on the other 3 pedals, I offer my solution for your viewing pleasure :cooler:....
I'm finding this combination really good for me. I'm about 5' 10" with size 9 1/2 shoes so your pedal placement could be adjusted to your size. This may give someone a place to start.
I'd be interested in the solutions others have come up with.
Cheers,
Steve
1963 BJ7 Works Rally replica w/EFI
dougie
Steve - A dead pedal is a must especially when racing a big Healey. I find a "super size" pedal gives me added support while cornering a high speeds. I have also modified my throttle pedal for easier head-toe braking.
In this picture you can just make out the air-duct from my rally vent at the upper right. This really helps to lower the air temperature around my feet when racing in the summer.
Dougie
Lin
Steve,
Excellent job on the write up. After I install a set of Dr. Nordquist's narrower pedals I might even be able to get my 11 1/2" shoe over to the dead pedal location! The Denis Welch alloy pedals make that impossible at the moment.
Thanks
Lin
HealeyPassion
HealeyPassion
Dougie, I do love the look of those pedals but my feet would have a hard time with them. Living out in the sticks in Colorado, I'm usually wearing hiking boots and they don't navigate between close pedals very well.
Lin, I'm looking forward to seeing those pedals. Mick hasn't sent me a pic of them. I may want to go that way....they sound great.
Cheers,
Steve
K TR2/3/3A The Dead Pedal Triumph 3
petnatcar Dead Pedal Austin Healey 12
petnatcar DEAD PEDAL for a BT7 Austin Healey 25
R dead pedal for '74 midget? Spridgets 4
HealeyPassion Dead pedal for 5 speeds Austin Healey 5
K TR2/3/3A TR3 "dead pedal"? Triumph 9
DerekJ Batteries Going Dead Austin Healey 9
T MGB MGB Dead Short? MG 8
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R How old is "dead" FORUM Navigation Questions 5
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
FlyingCat Spitfire Dead Starter? Triumph 18
Sopwith_Camel dead at the finish line Spridgets 10
6 Dead Circuit ARRGH! Spridgets 13
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
L TR6 need help on long dead TR6 Triumph 16
2billydavies TR2/3/3A dead battery... until i disconnect the wire from coil to distributor Triumph 10
T TR4/4A Flat/dead spot on the starter? Triumph 5
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
M TR2/3/3A Finding top dead center Triumph 6
GTP1960 TR2/3/3A Fuel pump inertia switch vs. dead engine switch? Triumph 14
JPSmit Truck diagnostic advice needed [I suspect it is dead!]] Other Cars 7
sim Dead spark plugs ? Spridgets 52
JPSmit Sometimes I am surprised I am not dead Spridgets 15
P Turning to Top Dead Center Austin Healey 11
RickB All 4 parking lights dead, fuses all good? Spridgets 6
dklawson Alex Moulton Dead at 92. - 12/10/12 British Motor Corp 1
NardisCNC DEAD Battery Question...... Spridgets 12
D Dead Boot -- What do you know about this ? Jaguar 6
G DEAD BATTERY Austin Healey 4
M Top Dead Center Triumph 48
L I see dead cars... Austin Healey 9
D Car seems to have a dead battery [I no it's good] Spridgets 13
G GRRRR -- Dead in the water again!! MG 6
DanNagy Spitfire Jumping a dead battery on a Spit MK1 Triumph 7
S Wedge TR8 starter dead spot? Triumph 26
G Gauges dead after wash Spridgets 6
vping Dead battery or Genny gone south? MG 8
davester The Prince of Darkness strikes! Dead starter MG 15
KVH Triumph Activity Dead on Ebay Triumph 8
JPSmit Top Dead Centre Question Spridgets 24
C Dead Again... Triumph 25
T Crypt car driving in the dead of night Triumph 10
2wrench Number 1 cylinder, top dead center Triumph 51
Shealey OT: Boyd Coddington Dead at 63 Spridgets 10
beaulieu TR6 TR6 project with one dead cylinder ? Triumph 10
Nunyas Dead in the water... MG 22
B MGB MGB Cuts out, Tach goes dead..... MG 18
Z Charging/Dead Battery Problem Spridgets 8
W Dead tach MG 5
