You mean, "removing from the dash?"
1) Unscrew cable (at center).
2) Remove two illumination bulbs (one each side, a little below center) and high beam indicator bulb (speedo only, center bottom)
3) Remove two round securing nuts. (behind the securing bracket, a little above center, one each side)
4) Pull gauge forward, out of dash, and retrieve securing bracket from the floor, where it has fallen.
Since you are fiddling around near things that can arc and sputter, it's wise to disconnect the battery first.
