Centering the Steering
Steve1970
Still waiting for my clutch & other parts to arrive, so I worked on some other less-than-critical issues this weekend..
I have noticed that when the turn signal cancel clip is in the "centered" position, my front wheels are not. What is the common method of getting the t.s. cancel clip centering in line with the front wheels centering? Do I disconnect the steering column at the rack and rotate the column shaft until she's in line?
Geo Hahn
On my cars I find this is most easily done by adjusting the tie-rods on each side an equal (but opposite) amount.
I mark with a spot of paint and count the flats as I turn. If your alignment was correct before it will be correct after.
You wouldn't want to do big adjustment this way as it might change the geometry of the steering (and disguise a real problem) but for fine tuning it has worked for me.
TR3driver
Great Pumpkin - R.I.P
If it's off enough to affect turn signal cancelling, then I would start with changing splines on the column.
Ideally I think, you should center the rack first and then adjust everything else to match.
70herald
Um not sure about this. After I put the front end all together, I brought my car over to my friendly local mechanic (who is amused by my madness and willing to help out) We spent about 2 hours adjusting the rack / angles etc. It is amazing how much turning " a few flats" affects the geometry of the front end (even if you do this on both sides) It is also amazing how much better the car tracks, handles and drives with the front end aligned properly.
Steve, if the front end is properly aligned you just need to release the steering shaft from the rack, rotate it to the correct location ( and then maybe correct the angle of the steering wheel relative to the shaft also)
If you have not had the car aligned, do that first and then line up the rest of the steering system to the rack. It is not particularly expensive and makes a real difference.
Andrew Mace
In this particular situation, I think I tend to agree that a thorough check of alignment, and THEN correcting the wheel and/or column position, would be a good idea.
Several years ago, I replaced tie rod ends on a friend's Spitfire. I was very careful to count the turns required to remove each tie rod, so that I might at least get it "close enough" to drive away. In doing so, I discovered that one tie rod end was screwed in nearly as far as it could go, while the other one was only on by about a half-dozen threads. Not liking that at all, I did manage to more or less "balance out" the number of turns on each of the new tie rod ends as I installed them.
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
Woodie centering the steering wheel Spridgets 7
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
steveg HD series Jet Centering - a Caution Austin Healey 19
F TR2/3/3A Centering The Jet Triumph 14
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
KVH General Tech Centering Real Main Seal Triumph 4
K SU's again...Jet centering? Triumph 7
Nelson SU jet centering Spridgets 11
H HS6 Fixed needle centering tips Triumph 1
T Is the PDWA selt-centering? Triumph 6
D Jet centering tool Triumph 3
SilentUnicorn SU centering tool Restoration & Tools 2
W Centering The Needles MG 5
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
