Is the PDWA selt-centering?
TR6BILL
I am in the process of replacing all four of my rubber brake hoses from the frame to each wheel with new braided hoses (Whew! They are proud of those things!) I cut the rear hoses and let the brake fluid drain out of the rear lines (Weelll, not exactly. The wife pumped the brake a few times. Prolly shouldn't have done that.) Will cut the front next when the car goes back up in the air. (Still trying to finish the TAs and need to do some guess-shimming before taking her down the road to the alignment shop.) Time to replace all my old brake fluid again. (Yes, I am still using Castrol LMA Dot 3. I have a love/hate thing with paint.) Anyway, because she pumped the line a bit, did the PDWA go off center? And the big question is, will it self-center after all lines are back in and new fluid is placed? Will do the traditional de-bubbling at the furtherest drain point and so on...
PeterK
You will probably need to pull the switch and center the PDWA valve. But it's a good time to check and replace the o-rings anyway once all the fluid is out.
TR4nut
Bill-
You don't necessarily need to pull the switch, but it helps if you know which side might have been at low pressure. I did this before on my 6, and I was able to recenter by opening up the bleed valve on the other system and pumping until the light went off.
Randy
Platinum
Agreed. And I've had the diabolic things 'toggle' back and forth trying to center 'em with just pressure. If you go thru it and then center it 'manually' one time it should be good for another decade.
TR6oldtimer
TR4nut said:
Bill-
Randy
I have used the same technique. Once you convince the wife to get under the car with a wrench on the bleed valve, the procedure works well. Resetting it through the switch also works and allows you to see if it is leaking.
M TR6 PDWA valve Triumph 6
M TR6 PDWA Issue Triumph 5
S TR2/3/3A Pdwa Triumph 6
M TR6 Early vs newer pdwa for Tr6 1975. Triumph 3
SherpaPilot TR6 PDWA Leak Triumph 7
M TR6 Pressure differential warning assembly PDWA valve Triumph 4
brgrmyster GT6 What's the purpose of the ball bearing in the PDWA switch? Triumph 1
sparkydave PDWA rebuild Spridgets 13
R PDWA Wiring Triumph 29
I PDWA switch rebuilding help Triumph 12
Scott_Hower PDWA; tips for getting the shuttle out of it. Triumph 3
I TR6 TR6 PDWA switch help please Triumph 10
hondo402000 wanted Hazzard bezel or PDWA warning bezel. 71 TR Triumph 0
hondo402000 PDWA Rebuild Triumph 18
dklawson PDWA Switch Terminals & Rebuild Triumph 6
MTribe PDWA leak - how to fix? Triumph 6
Brosky PDWA & Rheostat Rebuild pages competed Triumph 6
red_tr250 Stag Stag PDWA vs TR6 Triumph 2
D PDWA switch? Triumph 15
jjbunn PDWA Seal Bolt Removal Method Triumph 12
jjbunn Brake Master Cylinder and PDWA Questions Triumph 11
B PDWA switch query Triumph 2
Brosky PDWA De-Mystified Triumph 29
A Permanent fix for PDWA brake switch Triumph 19
SpannerMan TR6 Source for TR6 pressure switch [pdwa] rebuild kit? Triumph 21
Scott_Hower Sectioned PDWA photo MG 24
G Gonzo PDWA valve Triumph 30
71tr PDWA Valve O-Ring Material Triumph 6
cutlass29 Spitfire spitfire mk3 '70 brake pressure switch pdwa Triumph 1
Scott_Hower Radiator back in and brake PDWA leak MG 3
77MidgetMkIV PDWA rebuild Spridgets 7
tr6web TR6 PDWA switch TR6 Triumph 5
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
steveg HD series Jet Centering - a Caution Austin Healey 19
F TR2/3/3A Centering The Jet Triumph 14
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
KVH General Tech Centering Real Main Seal Triumph 4
K SU's again...Jet centering? Triumph 7
Nelson SU jet centering Spridgets 11
H HS6 Fixed needle centering tips Triumph 1
Steve1970 Centering the Steering Triumph 4
Woodie centering the steering wheel Spridgets 7
D Jet centering tool Triumph 3
SilentUnicorn SU centering tool Restoration & Tools 2
W Centering The Needles MG 5
