carpets ???
twigworker
A customer is getting to the point of installation of carpeting and floor insulation on his TR3 and it has been two eons since I had to buy one.
I am open to suggestions, preferences and out right bias for different kits and vendors.
Jack
NutmegCT
Jack - there are tons of BCF threads on carpeting and insulation. I used foam carpet underlayment as the heat insulation. Tremendous improvement.
Edit: I think the link to Jack's Cars is broken in your signature line. Takes me to a blank page. But if I type in the link manually in my browser, it works fine.
Tom
T
twigworker
Thanks on the site link Tom !
I intend to have him install some insulation/sound deadening material in places that will not ordinarily be soaked by water, but I wanted to know if there was a "latest and greatest" kit or vendor out there. I am going to push him for synthetic in a cut pile in black. The transmission cover will be "tacked" in place with strategic spots of adhesive and some of the rest, as in the fender covers, will be permanently installed, but the flooring will be removable as much as possible to help with the inevitable dry outs.
NutmegCT
Now your link works!
I have old black wool carpeting - but still looks good and serves its purpose. I didn't tack down the foam at all - same reason as you. Wanted to be able to easily remove it in case it were to get wet. I find the original carpet hooks hold it all in place anyway.
T
twigworker
Unless I am convinced otherwise I want him to avoid natural wool as I am afraid that in our humid climate and since the car is going to to be stored under a car cover under a car port I don't want any mold or mildew issues. Thoughts?
Yep, I fixed the link but it was a pain. I like Basil and I like this site, but it is rather clunky in the maintenance department. Hard to find things, difficult to remember how to find them and then there is, at least to my knowledge, no "test" folder that changes can be run through before tossing them out into the real world.
Gotta go back to bed for a while. I was up way too early with a sick puppy.
NutmegCT
PS - I did a *lot* of comparisons before deciding on the simple carpet foam padding. The big name stuff as well as cheap HD stuff. Laid them down over a known heat source and measured temp of the padding after ten minutes. None in their standard thickness actually reduced "heat creep" as well as the stuff I chose. Came in a $10 six foot roll similar to this:
NutmegCT
Quick thought on the moisture question - if the car is stored outdoors under a car cover, you're almost guaranteed to keep moisture inside. Encourages mildew - not good. Free air flow is much better than "enclosed" outdoor storage, I'd think.
Tom
CJD
It's always a pain if you live in a humid environment. If you cover, you get mildew. If you leave open, the dust, pollen and dirt cover everything just as badly.
The best may be to use just a dust cover...not waterproof. That should keep the dust out and prevent the humidity from accumulating...
LAW75 Wanted Carpets Austin Healey Classifieds 0
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
P New member TR2 carpets Triumph 7
S TR2/3/3A back to carpets Triumph 13
Simmo TR6 CARPETS advice pleaese Triumph 7
N Carpets????? Spridgets 13
TomMull Post-War Other Herald carpets and throttle issues Triumph 4
TomMull Post-War Other Herald Carpets, issues, and minutia Triumph 4
N Best Carpets? Spridgets 5
R 100-4 carpets - chapter 2 Austin Healey 0
R New 100-4 carpets Austin Healey 1
C New carpets Spridgets 3
T ordinarily I like to do my own legwork but - carpets ? Triumph 9
JimTR4 Carpets Triumph 10
A Austin Healey mk3 1965 templates carpets search Austin Healey 1
J Spitfire Early Spitfire carpets Triumph 13
B Big healey carpets Austin Healey 1
bighealeysource Originality of carpets for BN6 Austin Healey 4
Number_6 Re dying old carpets Triumph 10
tinman58 TR2/3/3A TR3 Carpets Triumph 5
davidb Big Healey carpets Austin Healey 8
bthompson Snappy carpets Spridgets 11
tinman58 carpets and interior Triumph 10
T Black carpets with tan seats - anyone go there? Triumph 8
newmexTR3 TR2/3/3A TR3 Carpets- TRF vs. Moss? + TR move from NM to NY Triumph 21
chicken Tar paper under carpets Austin Healey 16
Brian_Lekas TR6 TR6 Carpets Triumph 20
AnitaO Original carpets...replace? Austin Healey 12
DrEntropy Carpets on the floor! MG 8
vping Dying carpets MG 3
J carpets or panels, Which First MG 2
I Carpets MG 5
