IF and that's a big 'if' there is any "precision" in the Unisyn, it's going to depend upon the user to utilize it...Set it 1/4" different over the mouth of one carb than the other will make you think the carbs are not in sync when they are ....or conversely make you think they are synchronized when they are not.
Doesn't the same thing apply to the hose hiss method? I have never tried it, the main reason being I did't figure I could accurately hold a hose the same distance as well as the same angle of the hose in relation to the carb or my ear for that matter) consistently. At least with the uni-syn you place it right on the carb and can see if centered or not, and it's design will always be in the same angle from carb to carb as the airflow.
Anyway, seems to be a subject of much debate, the wire things sound interesting, but have never tried them. I guess I trust my sight to determine "sameness" from carb to carb better than my ears.
Most everybody seems to have their favorites, maybe based on what you have done forever, or what somebodys showed you, or what makes sense intuitively to you (I think that last one is part of the reason I like the uni-syn) That is fine, they are British cars, if you get it to run right the method you use works.
Have been using a uni-syn since forever, is pretty intuitive and seems to work fine.
