Cant remove crank sproket???????
ALLAN
I have already tried puller with lots or pressure----used a little heat around sproket, dont want to beat on the end of the puller too much-- as the crank is already installed. Now W H A T???? the bushing, slinger and gear are all together and none of them are coming loose, Help
trrdster2000
Allan, try going the other way slightly, just to brake it loose. You can use a large socket, if you have one that big or a pipe, just so you can get a all around pressure on it, don't bang it too hard. Wayne
A
ALLAN
Thanks----that worked
It worked---only had about .010" to drive it back but it worked. It hung up 3 more times as it came forward so I had to drive it back each time to get it loose, then it was 1/8" at a time as it would pop and then I would have to get another bite with the puller, It took about 1 1/2 hr. and I had to talk to it alot!!! There is a groove on the bushing that the seal rides on--is that a machined groove or worn from the seal??
Banjo
Re: Thanks----that worked
Thats worn in from the seal. If not fixed it will leak. Either replace the pully (like that's an option) or look into a "speedy sleeve". That is a thin ring of metal that fits snugly over the old surface, making a new one. If Moss dosen't offer it, you should be able to size one up at the local parts store.
A
ALLAN
Re: Thanks
The groove is on a seperate bushing (collar) that the seal rides on, the pulley slides up against it. Mabey I can reverse the collar?, or get a new one from Roadster Factory, Thanks
piman
Re: Thanks
Hello Allan,
if the groove is not central then, as you say, just reverse it. Otherwise replace the seal but do not drive it fully home in the chain cover. If you can get the seal running on an unworn part of the sleeve it should be OK. Oil the sleeve when you fit the chain cover, loosely fit all the screws\nuts etc, turn the engine a few times then tighten the cover down.
Good luck,
Alec
G
Re: Thanks
Allan, not sure that the oil seal sleeve is reverseable in that the back-side bevel is designed to engage for future removal. New ones are available and relatively inexpensive. Surely put a new spring-loaded seal for the chain cover in, this is cheap insurance. Aren't SpeediSleaves designed to go over shafts - how would they fit over a keyed shaft? You are right that TRF has all this new. Just replaced them all. There is a firm out there were you live that will rebuild your pulley, about $90 if interested call Dave at TRF.
Bill
Banjo
Re: Thanks
If the oil seal ring is available seprate, then that's the way to go.
The speedy sleeve, if you had to do that, would fit around the seal surface of the ring, not the keyed shaft.
KVH
Allan, it would really help a novice like me if we could see some pictures of what you were doing and went through. Just a thought--in case.
A
ALLAN
Sorry dont have any pictures, but if you look at pictures in a repair manual that would give you the idea. When you get to a picture that shows the timing cover off and a view of the timing gear--just picture trying to remove the small crank gear with a gear puller, if its stuck on then you will have to go through what I did (above). I ended up ordering the new spacer that the oil seal rides on.
TRED
Glad you got the things apart. Just a FYI, but I have had trouble with things being stuck and had the puller cranked down very tight. What seems to work well is a sharp blow to the stuck part with a hammer, just be carefull, the puller can really jump when things come loose.
trfourtune
worn grove in bushing? i've had a local shop repair this type of problem in my other vehicles (worn axle at seal)by having the surface built up again by spray welding and then ground down. this can give a harder, better surface and you don't have to mess with those sleeves. a much more permanent fix. any shaft worn at the seal can be repaired this way.
rob
bobh
A little side information;
Speedy Sleeve is a product made by Chicago Rawhide. If you ever need a seal for a shaft you may want to contact them. In a previous life I used their wiping seals on a manual leveling system on an optical tracking platform for NASA.
It appears that CR is now part of SKF. You can see their Speedy Sleeve info here;
https://www2.chicago-rawhide.com/speedi_sleeves.htm
A
ALLAN
I bought the new sleeve--bushing--spacer (which ever it is called) from the roadster factory for $18 and it didnt even have to be backordered!! I think this is better than having to find a speedy sleeve or having it welded. Thanks for all the input, Allan
T MGB-GT cant rails on 1967 MGB GT MG 12
Healey Nut If you want a M but cant afford the real M price tag Austin Healey 24
T TR4/4A Heater control valve - cant completely turn off Triumph 3
F White smoke and I cant figure it out. Spridgets 17
W MGB MGB- Cant find reverse on my Moss 5 Speed MG 2
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
UmmYeahOk GT6 Cant restore my GT6 - what do I do? - [long] Triumph 39
justin_mercier Wedge it's true, you cant own just 1 LBC... buying a TR7 Triumph 15
glemon Help Cant Bleed Brakes Triumph 15
jaegzie Ive searched/cant find thread master cylinder BE Spridgets 6
texas_bugeye Blown head gasket that cant be good! Spridgets 10
S Cant remember where they go !! Spridgets 9
zimmy cant... install... windshield.......help wanted! Spridgets 15
B Help..Clutch not Engaging..Cant Shift Spridgets 4
Woodie Cant find my reference papers Spridgets 4
A Cant bring up private messages--Help!! Triumph 2
O have pics cant post Triumph 22
kbash OMG I cant beleave this happened to me :[ MG 0
G So why cant you do this here? Other Cars 9
6 Cant get the engine to go the last 2" MG 45
1 MGB My new 1977 MGB? cant turn distributor MG 3
A looking for a piece that i cant find MG 8
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
CARSINC How to remove factory contact cement? Spridgets 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
