cam gear orientation - what am I missing??
MTribe
I have a feeling this has been asked before, but wasn't able to find it with a search...
I installed a new camshaft (goodparts gp2), and new cam and crankshaft timing gears.
As per Bentley, I turn the cam until valves 11 & 12 are "on the rock," presumably just as one starts to open and the other is just finishing closing.
Then when I install the cam gear such that the dot near the bolt hole of the gear lines up with the dot on the cam itself, the other dot/line on the cam gear is 180 degrees out of phase with the corresponding engine plate markings.
That is, when I rotate cam so 11 & 12 are on the rock, then line up the dots on the cam and cam gear and mount the gear to the cam, the dot/line is at about 1 o'clock when it should be at 7 o'clock to line up with the dot/line on the engine plate.
What am I missing?? Maybe it's just late, but how do I ensure I have the cam gear properly oriented to the cam shaft?
Thanks!
Platinum
TWo diff'rent "methods"...
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Csarneson BN4 Cam Gear Install Austin Healey 3
W Cam gear position BJ8 Austin Healey 11
J MGB MGB cam, gear? MG 3
R Cam gear nut correct torque Austin Healey 2
B Moss adjustable cam gear MG 5
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
Walter74 Kent AH4 cam shaft Austin Healey 18
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
R TR6 Cam choices? Triumph 23
T TR4/4A Core Plug - Cam Rear change Triumph 7
D cam bearings Austin Healey 23
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
E TR6 Some cam questions Triumph 9
steveg Denis Welch mild cam Austin Healey 9
B Twin OH Cam for the BIG Healeys Austin Healey 15
K TR2/3/3A Street cam again and Valve gap? Triumph 6
K TR2/3/3A Mild street cam and Idle? Triumph 13
T Spitfire Cam shaft Triumph 3
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
Marvin Gruber Cam shafts for 3000 Austin Healey 2
J TR4/4A Cam Timing with Head Still On HELP! Triumph 8
K Kastner "F" race cam. Racing 3
