CAM BEARING REPLACEMENT
Tinkerman
Recently I wrote about needing some info on cam bearing replacement. Today a friend of mine came over. He is an engine machinest of some 20 years experience. He had a universal cam bearing tool. It is a tool that you put into the cam bearing and using a bolt you expand the tool to a snug fit and just pound the rascal out. Worked like a champ. to replace the bearings you put the tool in and bang them back in. Took about an hour and a half. My description is an over simplification. alligning the oil holes is a real challenge, using a red marker and a bore light allowed us to get them in correctly the first time. This is not a job for a beginner! I'm a pretty good wrench but I had no clue on either the application of the tool or how to put them in. This is one job best left to the professional!
y thanks to those of you that shared your experience's with me. It certainly helped! /ubbthreads/images/graemlins/cheers.gif
Tinkerman Cam bearing removal and replacement. Triumph 3
B TR4/4A Front cam bearing Triumph 8
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
tinman58 General Tech Cam bearing line bore Triumph 20
britlover TR4/4A TR4 Cam bearing locator bolts... Washers? Triumph 4
M TR4/4A Cam Bearing Install - TR4 Triumph 9
TR4nut TR2/3/3A TR3/4 Cam Bearing Install Triumph 14
M Cam bearing question and FO8 question Triumph 10
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
Walter74 Kent AH4 cam shaft Austin Healey 18
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
W Cam gear position BJ8 Austin Healey 11
R TR6 Cam choices? Triumph 23
T TR4/4A Core Plug - Cam Rear change Triumph 7
D cam bearings Austin Healey 23
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
E TR6 Some cam questions Triumph 9
steveg Denis Welch mild cam Austin Healey 9
B Twin OH Cam for the BIG Healeys Austin Healey 15
K TR2/3/3A Street cam again and Valve gap? Triumph 6
K TR2/3/3A Mild street cam and Idle? Triumph 13
T Spitfire Cam shaft Triumph 3
J MGB MGB cam, gear? MG 3
