Bugeye oil pressure line
R
rossco
Rick. The big pipe comes out of the oil filter and enters the back end of the block. About an 1 1/2" below that entry point is a suspicious looking bolt that enters into the side of the block. Almost straight in. Did a PO block the hole in question and disengage and nullify that side the gauge? The oil pressure side of the gauge its self shows no evidence of use for a long time.
RickF
This is where the oil pressure gauge line should be connected. 😁
R
rossco
Yep. The PO put a bolt in there and blocked it off. The lash up to get it going must have been too involved to go to the trouble. Parts and cost probably added to that decision. Guess I have a decision to make. I've been reading on the forum about what it would take to fix it. Don't know if my gauge is operational. He may have that opening to the block boogered up. Any thoughts?
RickF
The oil pressure gauge is pretty important in my opinion. I would get the gauge working. The block fitting is normally available from Moss, but is on back order at the moment. Every A-series engine put in a Sprite and Midget had an oil pressure gauge, so used parts are out there. Once you find the fitting the rest is easy. Oreillys, Advance, Autozone, etc. all sell an oil pressure tubing set with fittings that work on the Smiths gauge and the fitting on the block. You can get a kit with nylon tubing or brass tubing.
vping
Bronze
Cash you post the moss part# for future reference.
twas_brillig
Bayless
vping
Bronze
Yeah MOSS number is more helpful on account of my account with them.
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
T Oil Pressure-Bugeye Sprite Spridgets 12
E Bugeye Oil Pressure Gauge Spridgets 5
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
I Bugeye oil leak help Spridgets 4
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
I Bugeye oil pan help Spridgets 3
I Bugeye dash pot oil level Spridgets 3
M What is the proper oil for Bugeye engne and transmission Spridgets 6
M Oil filter on Bugeye question Spridgets 4
Rut Bugeye oil leak Spridgets 8
P Bugeye Water/Oil Combo. Gauge? Spridgets 4
P Bugeye oil/water gauge? Spridgets 6
DanLewis Solved the oil cooler mounting problem in my Bugeye! Spridgets 8
DanLewis Other ways to mount an oil cooler on a Bugeye Spridgets 3
I oil/oil additives for stock Bugeye engine? Spridgets 10
Kurtis 1275 Oil Filter Change on a Bugeye... Spridgets 10
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
