BT7 Steering Box - Tube connection
germanmichel
Hello @ all,
I would like to ask the specialists about the connection between the outer tube and the housing of the steering box. Is it a pressfit connection ?
In my case it is a light snug fit of the tube outer diameter, to the muff of the steering box housing.
Currently without sealing at this connection because of the easy movement.
How it should be sealed ?
Thank you very much in advance for your advices.
Michel who is currently in world soccer fever..:excitement:
I've always thought/believed/speculated/etc. that the tube and box were soldered together, but I could be wrong. Since soldering wouldn't be a particularly strong joint, I figured it was a loose press fit, and the solder was there mostly to seal the joint (like fitting copper piping).
PTBJ
I recently rebuilt a steering box while converting it from a LHD to RHD. I was told buy a well respected restoration company in Australia (100S fame) that the tube to casting fit was silver soldered together. So after heating the area the two parts separated with little force. I then silver soldered the tube into new RHD casting and reassembled the steering box. I understand silver solder is stronger than just plain solder and is what plumbers use for copper pipe connections.
germanmichel
germanmichel
Hello ,
thank you for your information.
This makes definitly sense, but this is not easy to realise if the the housing is not really free of grease or oil contamination.
But I'm happy that you all understand my explanation in my question because of my german accent...
Bye Michel- who will fix it with silver soldering
D BT7 adjustable steering column / steering wheel Austin Healey 1
S 3000 BT7 Steering Wheel Restoration help needed Austin Healey 3
G MISC Q's: BT7 Tranny, Tighten Steering Wheel, Rattle in Front End Austin Healey 11
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
