Bouncing Betty Speedometer Needle
Got_All_4
TR250's speedo needle was bouncing all over the place and speed was unreadable. I replaced the cable hoping that would work (it did on the TR3) but it only improved it. Still slightly bounces up to 45 mph straightens up nicely at 50mph. Just a slight bounce till 70mph then smooths out. What else can be going on here. Drive gear? Speedo it's self?
T
Tinster
It could be the inner cable is not inserted far enough
into the speedo or tranny to fully engage.
That can result in bouncing needle.
d :savewave:
70herald
Or it could be the speedo itself. I had a similar problem with my speedo until it broke the cable. Last week, I took it apart and found that the mechanism barely would turn. less than two hours work and it now works properly. To bad the engine is all partly disassembled or I could test the speedo.
Here are instructions:
https://home.comcast.net/~rhodes/speedo.pdf
sail
Look for this thread originally posted 1/28/08 by davidk "speedometer needle jumping"
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/459827/1
I just received my speedo back from Nisonger. This must be very common as it was on a preprinted card.
Important Notice: Examination of this instrument has revealed the presence of an excessive amount of oil which had entered via the flexible drive.
Before replacing it in the vehicle from which it was taken, please ensure that the inner and outer flexible drive is free from excessive lubricant and that whatever oil seal is fitted to the engine/gearbox end is in good condition and properly installed.
Lubrication of the inner core should consist of the application of a good quality low temperature grease; all excess should be wiped off with a rag before assembly of the flexible drive.
angelfj1
Also, make sure that the cable has no kinks anywhere. This is critical and be sure the cable is lubricated. Lithium grease is good for this. Is this a standard or OD transmission? If OD, check the right-angle drive to be sure it is operating smoothly.
Got_All_4
Got_All_4
This is a standard non OD trany. I did lube the cable with a thin oil. For sure no kinks. The cable comes straight out of the trany with a long bend that is attached to the brake lines with a cable tie. Then it make the journey up through the grommets and another long bend into the fire wall and to the back of the instrument.
angelfj1
Remove the speedo from the dash but leave the end of the cable protruding so you can watch the inner cable move. Either with someone else driving or with the rear wheels off the ground, watch the cable turn as you change speed. Is the motion smooth or jerky? If it's jerky, your cable is either bad or needs better lube. Go to a motorbike shop and ask for speedo lube. Comes in a small tube like toothpaste. BUT don't over do it. Some mechanics only lube the bottom 2/3 of the cable. The lubricant can/will move up the cable and can enter the back of the speedo and really gum up the works. If the cable is fine, AND the speedo is still jerky, you need to send it for R&R
T
TRDejaVu
I followed Tony Rhodes instruction document and took mine apart over the winter. I cleaned it (quite a bit of oil sludge from the cable had got onto the drag cup), found no obvious wear items and put it back together. It worked nicely for a few miles then started sticking. Took it apart again and gave the "too clean" drag cup a little 3-in-1 oil. Has worked very nicely for about 500 miles with only the slightest occasional flicker.
KVH General Tech Speedometer Pointer Bouncing Around Triumph 22
I TR6 75 TR6 Speedometer bouncing Triumph 7
K TR2/3/3A The TR3 Bouncing Ammeter Gauge? Triumph 6
V TR2/3/3A Bouncing Tach on TR-3B Triumph 4
D Bouncing Tach Needle Spridgets 2
S Spare Tire Bouncing Around Spridgets 2
S Bouncing Tach on Series III E-Type Jaguar 4
M TR2/3/3A HVDA Speedometer Drive Triumph 10
GeorgetheTR3 TR2/3/3A Speedometer Triumph 4
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
roscoe GPS Speedometer Austin Healey 6
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
DocDup1 MGB SpeedBox Speedometer Drive MG 0
R TR2/3/3A Speedometer Reset Triumph 26
BritBite Speedometer Right Angle Drive Austin Healey 5
roscoe GPS Speedometer Austin Healey 10
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY Speedometer Fluctuation Austin Healey 21
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
M TR6 Speedometer Triumph 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
P TR6 Jumpy Speedometer cable Triumph 4
PAUL161 T-Series Interesting Speedometer Scenario MG 5
John Turney Getting Speedometer out of the Case Austin Healey 6
K TR2/3/3A Speedometer needle bounce? Triumph 1
P Speedometer confusion Spridgets 1
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
RJS TR4/4A Speedometer and Angle Drive Triumph 6
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A Speedometer Works Removal Triumph 10
R TR2/3/3A Speedometer Routing Triumph 15
KVH General Tech Speedometer Not Working Triumph 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
K TR2/3/3A Speedometer Error Again Triumph 8
G Spitfire gps speedometer Triumph 6
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S Speedometer Angle Drive Austin Healey 2
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
F How does overdrive Annulus effect speedometer Austin Healey 10
M TR4/4A Speedometer Cable Routing Triumph 7
2 TR2/3/3A Can't get zero on speedometer 60K tr3A Triumph 6
B Speedometer Cable Routing Austin Healey 9
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
Michael Oritt Speedometer drive issue Austin Healey 4
R TR4/4A Speedometer off 10mph Triumph 6
