So I am doing the body work on the spare tire panel and have some concerns. I heard a body shop man refer to a dented up panel as being walnut-ed when there were many highs and lows hooked together. I have been using a method of cleaning the piece, by sandblasting then putting on epoxy primmer over the entire piece then applying the putty where needed. I have been using that glaze putty and spreading it over the piece in low spots, but I am still getting that wavy feel because the area is large. the piece looks a lot better but needs more. It looks like I should try again and this time put a thin layer or the entire raised section of the spare door, and try and get that flatter/more even plan. This time I might use a sanding block because I could be digging in and creating waves, but again on a tr3 everything is arced at some point.
I want to get a system of laying the putty because both rear fenders are basically completely walnut-ed and I plan to do them next. I like the feel of glaze putty, but should I go to bondo on the rear fenders, but again I guess I should spread out a large area from the highest point and feather it all together
