bn6 drum brake front hubs
maxwedge5281
can the front hubs from a 1958 bn6 with drum brakes and steel wheels be used on a 1959 bn6 with disc brakes and healey bolt on wheels???
Don't think so. I believe the axle shaft size is different. You have to go a little deeper and change kingpin out as well. Ran into that when I put put disc brakes on my brothers 100/6.
Marv
steveg
Denis Welch &, AH Spares sell the adapter plates for mounting calipers on the older-style swivel axles. You can get them in the wider bolt pattern to fit the later Type 16 Girlings, 4-piston Girlings or 4-piston Toyota calipers.
The Moss catalog makes it look like the kingpin is the same throughout. My BJ8 swivel axles fit onto my BN6 kingpins no problem.
The main thing would be acquiring disc rotor-compatible disc wheel hubs from BT7/BN7 onward.
I believe there's an older post in the archives where Randy discusses what he went through for the conversion.
prb51 BN6 Owners Handbook Austin Healey 14
prb51 BN6 Wheel/Tire Combo Austin Healey 26
nevets BN6 Soft Top Webbing Austin Healey 2
BN6_2197 BN6 Static Timing Austin Healey 2
BN6_2197 BN6 Pulley Diameter Austin Healey 3
BN6_2197 BN6: How to case spikes of the screws of the door panels Austin Healey 17
nevets BN6 horn button Austin Healey 17
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
G BN6 Battery location Austin Healey 7
C How to remove entire dash panel on BN6? Austin Healey 4
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
G Rollover Bar BN6 Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
BN6_2197 Seat belts in BN6 Austin Healey 15
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
V Wanted BN6 Front Seats Austin Healey Classifieds 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
maxwedge5281 modified bn6 history Austin Healey 1
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
M First steps ... & BN6 Austin Healey 4
nevets BN6 rear brake pipes Austin Healey 15
C Healey BN6 water pump and overheating problems Austin Healey 11
maxwedge5281 bn6 spare tire shelf Austin Healey 1
maxwedge5281 BN6 Tonneau Cover Austin Healey 5
BN6_2197 Adjustment of the Ignition System of my BN6 Austin Healey 22
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
maxwedge5281 bn6 two seater spare tire shelf upholstery Austin Healey 4
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
maxwedge5281 BN6 rear quarter panels installation Austin Healey 4
maxwedge5281 bn6 two seater trunk Austin Healey 16
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
C routing of speedometer cable on BN6? Austin Healey 11
BN6_2197 Sun Shades for BN6 in Germany Austin Healey 3
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
A BN6 Top Installation Austin Healey 1
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
BN6_2197 BN6 brakes not working properly Austin Healey 9
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
David Townsend BN4 and BN6 Limited Edition Prints Austin Healey 30
BN6_2197 Distance Peace bearing for BN6 with whire wheels Austin Healey 10
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
BN6_2197 Removing the Swivel Pin of BN6 Austin Healey 5
BN6_2197 Removing Break Fluid from Bn6 Austin Healey 13
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
maxwedge5281 bn6/7 hardtop Austin Healey 18
maxwedge5281 changeover to negative ground in my bn6 Austin Healey 9
