TR6 Blower fuse
davjac889
Hello All,
As I indicated in my last post, I got my blower
working but now the fuse box gets super hot
and now I'm not sure what's going on. I know my blinkers and gauges
work off the blower fuse also.
Any thoughts would be appreciated.
Thanks,
Bill '73 TR6
Mickey Richaud
Sounds like it could be poor grounds - check all your ground connections, Bill.
TR3driver
Great Pumpkin - R.I.P
I don't think it's grounds. The heat means that there is an excessive voltage drop at the fuse block.
First question, what are you using for a fuse? Lucas repro or AGC?
Assuming you have either the proper Lucas "35 amp" or an AGC 20, then the problem has to be a poor connection at the fuse block. I'd start by polishing up the surfaces of the tabs that grip the fuse, with a Scotchbrite or similar, as well as the mating surfaces on the fuse. If that doesn't solve the problem, then you'll need to do some checking with a voltmeter or DMM, right at the fuse block, with the heater blower running. You should have no more than about 0.1 volts from the white wire (which is power in from the ignition switch) to the green wire (power out to the heater, turn signals, etc.)
I forget offhand how the TR6 fuse block is constructed; but on a Stag fuse block, there are copper rivets that are supposed to carry the current between the fuse clips and the wire terminals. Over time, the plastic shrinks until the rivets are no longer tight, and then the copper corrodes to provide a high resistance connection.
FWIW, I once had a similar problem with the (aftermarket) headlight fuses on my TR3A. Couldn't see any corrosion, but the tabs were not making good contact with the fuse even after replacing the fuse. The heat literally melted the solder inside the fuse! Which led to a fuse that was visibly fine, but would not carry current (the broken joint was hidden inside the end cap). Few seconds work with a Scotchbrite and the problem never came back again.
davjac889
Thanks Randall, I'm using AGC 20 and the fuse block is
of plastic construction mounted on the wheel well.
I'll try to clean her up but now I'm wondering if it
could be the fuse block?
Bill
RAC68 Cold Air Bilge Blower update Austin Healey 13
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
D Another use for a leaf blower. Restoration & Tools 1
Joe Schlosser Bugeye combo Heater blower Switch Spridgets 4
D TR6 Blower motor Triumph 1
steveg Heater Blower voltage drop Austin Healey 8
N Replacing Heater Blower Austin Healey 7
bugedd Heater blower wanted...oops Spridgets 8
D TR6 Blower runs off and on Triumph 4
D TR6 Blower working! Triumph 3
D TR6 Blower Triumph 4
L Fresh air and Blower intake hose replacement on BJ8 Austin Healey 12
maxwedge5281 heater blower ducting Austin Healey 6
D TR6 76 TR6 Heater/Blower Switch Triumph 1
R Heater Blower Motor Austin Healey 9
M About to install blower [pic] Triumph 9
R Blower assembly question Spridgets 1
P POLISHING HEATER BLOWER HOUSING Spridgets 7
I Shop to check heater blower motor in Washington? Triumph 6
I TR6 TR6 heater blower wires -what are these wires for? Triumph 8
S Heater Blower Installation Austin Healey 5
billspohn Oddball Defroster Blower Other British Cars 7
jvandyke heater blower wiring Spridgets 2
roofman Spitfire Spitfire blower fan won't turn off Triumph 5
F TR6 TR-6 Blower Bearing Noise Triumph 3
I bugeye heater blower attachmetn help Spridgets 9
bcbennett TR6 TR6 Blower switch Triumph 6
trrdster2000 Fix that blower switch Triumph 3
John Moore Midget with Blower FS Spridgets 1
Woodie heater blower, demister/defroster Spridgets 8
AUSMHLY Fresh air hose clamp, heater blower ground Austin Healey 5
ObiRichKanobi Shot Blower motor??? Triumph 1
zimmy TRADE?-heater blower Spridgets 3
MadRiver TR5/TR250 Silly TR250 Vent/Blower Question Triumph 1
Brosky Heater blower blowing fuses Triumph 6
T Blower Motor for 7 Triumph 1
T MGB 1980 MGB heater blower motor MG 1
T MGB Heater blower motor for 1980 MGB MG 2
B Blower Motor Always On Austin Healey 2
P TR6 72 tr6 heater blower Triumph 2
7 Sprite Blower Spridgets 8
T Blower Motor Triumph 0
M AC/Heater Blower Problem Jaguar 2
S Wedge TR7: Wiper & blower won't work! Triumph 6
T 1971 Fuse Box and Wiring Triumph 7
W General Tech 2500S starter motor and fuse box questions Triumph 3
B TR4/4A In-Line fuse 25 or 35 Amp? Triumph 21
B MG Fuse Location Spridgets 2
